Openlrs
- Xermalk
02 Nov 2013 17:32 #15256
by Xermalk
Openlrs was created by Xermalk
Could something like this,
www.hobbyking.com/hobbyking/store/__4003...h_Futaba_radio_.html
or
www.hobbyking.com/hobbyking/store/__2709...igy_compatible_.html
Be used with a devo 7e or 10?
or
- Xermalk
02 Nov 2013 19:38 #15264
by Xermalk
Replied by Xermalk on topic Openlrs
I doubt ill be flying so far out that i need telemetry, my 5.8 ghz 200mw link should give up before the openlrs does.
As for the battery that wont be a issue, ill likley have the module mounted on something or stuck on my car roof (while i hide inside in the heat).
- Xermalk
- SadSack
12 Nov 2013 11:32 #15540
by SadSack
Replied by SadSack on topic Openlrs
You have another options to connect OpenLRS to your TX. Transmit to it using either Spektrum or Turnigy/Flysky. Could use other RX as long as it outputs single PPM. I'd go for the Flysky and use this
HERE
Which would free up your PPM on your Devo for head tracker. Deviation only has one PPMin or PPMout and not at the same time.
