Devo10 warning?
04 Nov 2013 13:49 #15328 by tonyg7vkb
Devo10 warning? was created by tonyg7vkb
Hi everyone, I'm new to the site.
I recently purchased a Devo10 in mode2. I installed Deviation vers 3 and the file system from vers 2.1.
All appears okay except for one minor error.
When switching on I get a warning that Ch1[Ele] is 0% and safe value is -100?. If this were on Ch3[Th] I'd understand it.
How can I correct this issue?
04 Nov 2013 13:50 #15329 by FDR
Replied by FDR on topic Devo10 warning?
You should install the v3.0 filesystem for the v3.0 fw:
www.deviationtx.com/repository/Deviation...s-devo10-v3.0.0.zip/
04 Nov 2013 16:22 #15335 by tonyg7vkb
Replied by tonyg7vkb on topic Devo10 warning?
Thanks FDR, Thanks for your quick response.
I installed file system version 3 as advised and initially all was okay.
Then I changed protocol to DSM2 and the problem came back. Haven't found a way round it so far?
  • rbe2012
  • rbe2012's Avatar
04 Nov 2013 16:29 #15338 by rbe2012
Replied by rbe2012 on topic Devo10 warning?
When you changed the model or restarted the tx it should be gone.
This is a known problem because some variables are not initialized directly after changing the protocol but rather when the model is reloaded.
04 Nov 2013 16:36 #15339 by FDR
...or if you edit an existing old model config, which contains something like this in the [safety] section:
[safety]
Ch1=min
04 Nov 2013 16:50 #15341 by vlad_vy
Replied by vlad_vy on topic Devo10 warning?
After changing protocol from Devo to DSM2 channels mapping do not change automatically, you need change source to valid for first 4 channels, at mixer page.
04 Nov 2013 18:09 #15347 by tonyg7vkb
Thanks guys for your quick responses. I seem to be getting around the problems now with your help.
This is where I am at the moment?
Mode2
DSM2
Plane
6Channel
Throttle left stick[Ch1]
Rudder left stick[Ch4]
Ail right stick[Ch2]
Ele right stick [Ch3]
Gear gear switch
Ch6 3position mixer switch
I got here by loading a template for 6ch plane.
I did try editing the mixing without success. Thanks again guys.
Time to create page: 0.211 seconds
