Devo10 & Multiwii fail safe
08 Nov 2013 04:43 #15435 by Pattaya01
Devo10 & Multiwii fail safe was created by Pattaya01
You can use "Channel Monitor" to see if there is any signal from the TX.
08 Nov 2013 05:24 #15438 by FDR
Replied by FDR on topic Devo10 & Multiwii fail safe
Yes it will.
When reception is lost the rx will send the failsafe values if they are configured, or the other option is hold, i.e. send the last value...
08 Nov 2013 05:38 #15439 by vlad_vy
Replied by vlad_vy on topic Devo10 & Multiwii fail safe
I think multiwii fail safe will work with satellite Rx only.
  • rbe2012
  • rbe2012's Avatar
08 Nov 2013 06:14 #15440 by rbe2012
Replied by rbe2012 on topic Devo10 & Multiwii fail safe
I am not sure about MultiWii, but it does need an external receiver, or not?
If so, the failsafe values are sent to the receiver at bind time (when signal is usually good). When the receiver looses signal, it will give out the programmed failsafe values (say THR=-100%, AIL=ELE=RUDD=0) - the MultiWii still gets a regular input.
Maybe your receiver has a feature to give nothing out when it looses the connection to the transmitter. I have seen only those who continue to give out the last signal or the programmed failsafe values.
Time to create page: 0.323 seconds
