Throttle not spooling up
09 Nov 2013 16:50 #15476 by Kramard
Throttle not spooling up was created by Kramard
Hi Guys,
Sorry for all the questions. Other than using an MCX2 file, I'm unable to power up my Nano CPX. When I use a file for the Devo 7e the heli binds and the servos respond but the motor does not come online. This is the case with all the models.ini files I've tried. Any thoughts as to what I'm doing wrong? It seems as though throttle hold is activated and the switches are not turning it off.
Tx: Devo 7e
Heli: Nano CPX
Firmware: Deviation 3.0.0
Dave
09 Nov 2013 17:33 #15477 by Adriaan
Replied by Adriaan on topic Throttle not spooling up
Try to lower Travel Adjust-Throttle Value to -130, for me it helped to "unlock" throttle with dsm2 or dsmx copters.
  • rbe2012
  • rbe2012's Avatar
09 Nov 2013 19:43 #15478 by rbe2012
Replied by rbe2012 on topic Throttle not spooling up
Does the blue led flash (three times, then a break) or is it lighted steadily?
I had the same with the mCP-X these days. It needed more than one binding attempt with rudder full right without success, then switching tx and rx off, switching both on and bind again with rudder right until the blue led was on.
From now on it bound correctly each time and I can control throttle.
BTW, with flashing led ch1 controlled the pitch value...
09 Nov 2013 22:53 #15481 by Kramard
Replied by Kramard on topic Throttle not spooling up
Thanks for the right rudder comment. That did the trick. Flies even better on a .ini file created for a CP helicopter :).
Time to create page: 0.403 seconds
