problem on devo 8s "J6pro" protocol
- fredolabidouille
10 Dec 2013 11:32 #16467
by fredolabidouille
Hi guys, (and first, sorry for my English
I have a problem whith my devo8s on the J6pro protocol, binded on a solo pro 126 receiver.
everything is fine but the ruder I an't control
tail motor is working "full" as soon as I put a bit of throtle, and neither the gyro nore the radio have any influence on it.
I binded it on a J6pro and it works fine, so I think it's a channel attribution problem.
can anyone help, please ?
thank's
problem on devo 8s "J6pro" protocol was created by fredolabidouille
thank's
10 Dec 2013 11:46 #16468
Replied by FDR on topic problem on devo 8s "J6pro" protocol
Have you set up a gyro channel value?
I don't know which channel the Solo Pro 126 uses for the gyro value (if it uses one at all), but I would try to put a fix value on the Ch5 somewhere between 0 and 100%...
- fredolabidouille
10 Dec 2013 12:45 #16469
by fredolabidouille
Replied by fredolabidouille on topic problem on devo 8s "J6pro" protocol
thank's for answer !
but I've tried this way first.
and I have not any control on the rudder motor power by the rudder stick on on the radio. so I think I should have if it was a gyro value problem...
10 Dec 2013 14:43 #16473
Not necessarily.
Without a rudder stick change the gyro alone controls the tail motor.
If it thinks it should turn to stabilize, it will spin the motor faster and faster...
Have you tried to reverse the rudder channel?
- fredolabidouille
10 Dec 2013 15:27 #16483
by fredolabidouille
that's clever
yes... without any results
IndeedFDR wrote: Not necessarily.
FDR wrote: Have you tried to reverse the rudder channel?
- fredolabidouille
10 Dec 2013 17:33 - 10 Dec 2013 17:35 #16488
by fredolabidouille
Hi !
I finaly solve my problem !!!
it was the wrong channel for rudder :
I had the trotle cut on "gear switch" and gyro rudder DR on the "rudder DR switch"
the problem was that in the "gyro sens" menu, "channel" was on "aux2/ch7" (in order to allowed rudder DR switch to control gyro DR)
now (still in gyro sens menu) I turn "channel" to "gear/ch5" and it works.
then "gyro DR" is on the gear switch so I just inverted those 2 and put the throtle cut on "rudder DR" switch.
that's not realy logical but it works... so
Last edit: 10 Dec 2013 17:35 by fredolabidouille.
10 Dec 2013 18:21 #16494
I'm glad you resolved the issue.
I don't use the standard gui, so I'm not used to the different switch assignments. In the advanced gui you tell what goes to what channels...
Time to create page: 0.603 seconds
- problem on devo 8s "J6pro" protocol
