Hi problem with my devo-10
10 Dec 2013 14:18 #16471 by Syrabane
Hi problem with my devo-10 was created by Syrabane
Hi
ive followed the instructions to setup my devo 10 and copied the file system to the controller but the screen theres nothing on it i cant see any menus when i click the ent button i just see black squares any help would be appreciated thank you.
  • rbe2012
  • rbe2012's Avatar
10 Dec 2013 14:41 #16472 by rbe2012
Replied by rbe2012 on topic Hi problem with my devo-10
Make sure that you did not copy the folder "filesystem", only its content: the USB file system should contain folders like "media", "models" and some more and files like "tx.ini" and others directly in the root of the file system.
10 Dec 2013 14:47 #16475 by FDR
Replied by FDR on topic Hi problem with my devo-10
You probably copied the whole filesystem directory, not just the contents of the filesystem/devo10 directory...
10 Dec 2013 14:54 #16476 by Syrabane
Replied by Syrabane on topic Hi problem with my devo-10
i did im an idiot i just extracted the zip to the TX my fault thanks guys. Works a treat now. Will this bind to the Blade 350QX to?
10 Dec 2013 15:18 #16482 by FDR
It should...
10 Dec 2013 19:04 #16501 by Syrabane
Binds fine to my 350qx this firmware is awesome seriously 1000000x better than the stock. Wont hook to my Nano though :( still for my blade its wicked thanks a lot guys.
Time to create page: 0.207 seconds
