Low voltage
- harmony96
27 Dec 2013 02:33 #17076
by harmony96
Low voltage was created by harmony96
So far I had no problems flying skyartec nano cps using devo 8S with a tx module from skyartec radio. When I flew skyartec nano cp today, my heli suddenly was out of control. Also, as I tried to flew another skyartec heli, it was spinning on the ground. At that time, the screen of my devo8s indicates 4.68V~4.7V. However, walkera cps have no problems today.
If I remember correctly, devo 8s works properly for more than 3.3V. (There is a 3.3V regulator, right?) So, I set the low voltage of my devo 8s to 4.0V for safety.
Is there something that I missed?
Thank you.
Thank you.
27 Dec 2013 09:04 #17080
Replied by rbe2012 on topic Low voltage
You are right; deviation should work down to 3.3V besides the saving of config files which will not work with less than 3.8V. But there is some protection and a warning dialog built in. But even in this case controlling a bird should be no problem.
Are you sure that you used a rf module which works with 3.3V? If they have their own voltage regulator they might need a higher voltage to have something to regulate... I don't know the skyartec module.
- RandMental
27 Dec 2013 10:24 #17083
by RandMental
Replied by RandMental on topic Low voltage
Be careful NOT to run the input voltage at the Devo8s connector below 3.6 Volt.
We have done extensive tests:
www.deviationtx.com/forum/3-feedback-que...ttery?start=20#12374
and
www.deviationtx.com/forum/3-feedback-que.../1966-devo-8-battery
and
Time to create page: 0.169 seconds
