Master CP ESC to RX601 for DH 9100
29 Jan 2014 20:55 #19389 by drdisaster1
Master CP ESC to RX601 for DH 9100 was created by drdisaster1
I upgraded my Master CP to Brushless. I plan on replacing my DH 9100 receiver with an RX601 and the old ESC from my Master CP and converting it to 4ch. How would I plug the ESC from Master CP in to to he RX601. So far I have Main motor in the Throttle Channel and the signal wire for Tail in the Rudder Channel, but where would the Power Check plug in.
I have tried plugging it in to the GEAR and AUX1 channels but the heli seems to always stay at about 1/4 throttle even when throttle is at zero or TX is turned off. I have to reach under snd pick it up to switch it off. Maybe this is a TX problem, I'm not sure as I'm still new to this.
I really want to use the RX601 since I already have it and am on a budget.
29 Jan 2014 21:42 #19390 by WheresWaldo
Replied by WheresWaldo on topic Master CP ESC to RX601 for DH 9100
You will likely get a better/quicker answer if you go to rcgroups. There is a whole very long thread on the MasterCP and all it's upgrades.
www.rcgroups.com/forums/showthread.php?t=1664447
Time to create page: 0.893 seconds
