Emulator Basic Questions
- jazzjohn
01 Feb 2014 19:07 #19609
by jazzjohn
Emulator Basic Questions was created by jazzjohn
Is the Devo 8 emulator the closest one for emulating the Devo 6?
How do I simulate stick inputs?
Is there a manual or list of keystrokes?
Can the right-hand side of the window showing what I assume is debugging info be eliminated (for the purpose of taking screen shots)?
01 Feb 2014 19:42 #19615
Replied by rbe2012 on topic Emulator Basic Questions
(1) Yes.
(2) q/a, w/s, e/d, r/f are the sticks, Q/A, W/S, E/D, R/F the trims, the switches are located at the keys zxcvbnm (not sure which is what, but it is shown in the input monitor).
(3) Not as far as I know.
(4) As always: it is just programmed so the correct answer would be "yes", but this is something only a programmer could change. So for the user the answer is "no".
There is an emu for Devo6, but it is not published. I have compiled one with the actual code base (01/02/2014, 20:40 GMT-1) for you (guessed you're using Windows). You can use it with the Devo8 file system.
- Tom Z
01 Feb 2014 19:54 - 01 Feb 2014 19:58 #19616
by Tom Z
Replied by Tom Z on topic Emulator Basic Questions
Last edit: 01 Feb 2014 19:58 by Tom Z.
- RandMental
01 Feb 2014 19:54 #19617
by RandMental
Replied by RandMental on topic Emulator Basic Questions
In the Devo Manual is a list of keystrokes
- jazzjohn
01 Feb 2014 20:17 #19621
by jazzjohn
Replied by jazzjohn on topic Emulator Basic Questions
Wow thanks guys for the quick responses. You all must be having lousy weather today too!
01 Feb 2014 21:46 #19636
Maybe I should read the manual... it's a long time since...
Time to create page: 0.484 seconds
- Emulator Basic Questions
