File and GUI conflict
10 Feb 2014 02:20 #20047 by jazzjohn
File and GUI conflict was created by jazzjohn
The model file and the mixer page show AIL as a source for ch. 5, but the Expo&DR page for that channel does not show AIL as a source.
This seems like a harmless glitch since AIL is not really acting as the source for ch. 5, but I can't seem to get rid of ch. 5's AIL from the Mixer page via transmitter programming. I know the file can be easily edited, but I'm just curious why or how this happened.
(Devo 6s, Devo 8 emulator, v4.01)
  • rbe2012
  • rbe2012's Avatar
10 Feb 2014 07:47 #20055 by rbe2012
Replied by rbe2012 on topic File and GUI conflict
This is because the function is set to "fixed". This does not need a source so it is ignored. It has no influence to the mixer, but I agree: it is ugly.
I usually choose another function (like "1:1"), set a source I like (e.g. "GEAR") and set it back to "fixed". In the result "GEAR" appears in the overview. But as mentioned it is only a cosmetic issue.
10 Feb 2014 09:34 - 10 Feb 2014 09:34 #20059 by vlad_vy
Replied by vlad_vy on topic File and GUI conflict
At first firmwares by default source was 'None', later PB removed this option.
Last edit: 10 Feb 2014 09:34 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
10 Feb 2014 09:37 #20060 by rbe2012
In the gui the source is still "None", but the corresponding field is not reset and therefor written in the model*.ini file.
10 Feb 2014 12:41 #20063 by jazzjohn
Replied by jazzjohn on topic File and GUI conflict
That explains it. Thanks.
10 Feb 2014 14:58 - 10 Feb 2014 14:58 #20074 by PhracturedBlue
Replied by PhracturedBlue on topic File and GUI conflict
I actually tried fixing this once, and it ended up being more complicated than I expected so I gave up at the time (I don't remember why). It is definitely a bug though. If you file a ticket on bitbucket, I'll get to it eventually
Last edit: 10 Feb 2014 14:58 by PhracturedBlue.
10 Feb 2014 15:24 #20077 by PhracturedBlue
So changing the src to 'none is tricky because you can only do it when saving the mixer (otherwise the src gets reset while iterating through the spinbox). But the easy solution is to just mask it on the main mixer page instead. We already did that in the devo10 it turns out, so I just added it to the dveo8 too.
Time to create page: 0.122 seconds
