telemetry temp on main screen?
- chris-nc
19 Feb 2014 00:07 - 19 Feb 2014 00:47 #20553
by chris-nc
telemetry temp on main screen? was created by chris-nc
Using the DSMx or DSM2 protocol with telemetry enabled, I'm trying to configure two boxes on the main page, one for voltage, one for temp. When scrolling through the options for the box, the temperature option is missing. I know the temperature telemetry data is available as it is displayed on telemetry monitor page and updates with no issues.
Is this a bug? And if so, should I submit a bub report?
EDIT: by the way, this is on a Devo 10 with version 4.0.1, if that helps.
Last edit: 19 Feb 2014 00:47 by chris-nc. Reason: additional info
- WheresWaldo
19 Feb 2014 05:07 - 19 Feb 2014 06:13 #20566
by WheresWaldo
Replied by WheresWaldo on topic telemetry temp on main screen?
TelemTi - TelemT4 among other items are selectable on the main page config in box Big-box and Small-box. You could also select the telemetry page as Quick Menu1, Menu2 or Menu3.
Last edit: 19 Feb 2014 06:13 by WheresWaldo.
19 Feb 2014 07:49 - 19 Feb 2014 07:53 #20574
Replied by vlad_vy on topic telemetry temp on main screen?
But it is not right for DSM2(X) telemetry. Temp is missing, I can see ..., Timer4, FadesA, FadesB, FadesL, FadesR, Loss, Holds, TelemV1, TelemV2, TelemRPM, Ch1,...
Last edit: 19 Feb 2014 07:53 by vlad_vy.
- chris-nc
19 Feb 2014 12:26 #20578
by chris-nc
Replied by chris-nc on topic telemetry temp on main screen?
Exactly, I can see everything else in the list, it's just the 'temp' parameter that's missing from the list of selectable items for the main screen box configuration.
- WheresWaldo
19 Feb 2014 17:17 - 19 Feb 2014 17:21 #20588
by WheresWaldo
Interesting, did not know it was protocol specific. Is this a bug or intentional behavior?
Last edit: 19 Feb 2014 17:21 by WheresWaldo.
- gdrekuc
20 Feb 2014 00:38 #20621
by gdrekuc
Replied by gdrekuc on topic telemetry temp on main screen?
On Devo12S happens the same, no TelemT1 or TelemT available on the screen editor.
The alarms settings are algo buggy for the dsmx protocol. The Volt1-Volt2 voltage range are inverted, Volt1 goes from 0 to 25.5 and Volt2 is unlimited. The telemetry module Tm1000 sends the main battery voltage into Volt1 so in a >6s setup the voltage range is not enough. The Temp range has no values, so it is selectable but is useless.
Have you already reported a bug?
20 Feb 2014 04:12 #20632
Replied by PhracturedBlue on topic telemetry temp on main screen?
We can support 9 telemetry values to the main screen. I can make more available, but it would break the devo7e.
These are the available values. I can put them in any order, but only the 1st 9 will show up.
TELEM_DSM_FLOG_FADESA,
TELEM_DSM_FLOG_FADESB,
TELEM_DSM_FLOG_FADESL,
TELEM_DSM_FLOG_FADESR,
TELEM_DSM_FLOG_FRAMELOSS,
TELEM_DSM_FLOG_HOLDS,
TELEM_DSM_FLOG_VOLT1,
TELEM_DSM_FLOG_VOLT2,
TELEM_DSM_FLOG_RPM1,
TELEM_DSM_FLOG_TEMP1,
Maybe an order like this would make more sense?
- Kdean
20 Feb 2014 04:23 - 20 Feb 2014 04:27 #20633
by Kdean
Replied by Kdean on topic telemetry temp on main screen?
I dont know about the rest of the telemetry users, walkera and spectrum, but the rpm sensor is the least used for me. I dont even have an rpm sensor for my walkera telem setup. I can use a head speed calculator to get general head speed settings, and my cc ice esc's data log will tell me exactly where its at. Its more set and forget than the other possible sensors.
I would remove the rpm and put the temperature in the list of 9 possible sensors for display and alarm.
The rx signal sensors may be important to the fpv guys.
Last edit: 20 Feb 2014 04:27 by Kdean.
20 Feb 2014 05:05 - 20 Feb 2014 05:13 #20635
DSM2/X telemetry
1) By the way, at Telemetry config screen you can select many 'empty' sensors with 'Unknown' threshold. I think it's a bug.
2) It seems that 'Volt1' and 'Volt2' threshold limits interchanged or wrong. 'Volt2' (Rx battery) is totally unlimited (2000.0V) ???, but 'Volt1' (external voltage) limited to 25.5V.
3) 'Temp' threshold always '----' (not changeable).
TM1000 Telemetry module
RPM Range: 0 to 65,500
Flight Pack Voltage Range: 0–60V
Temperature Range: -40°F to 1000°F/ -40°C to 538°C
Receiver Volts: 0–8.0V
Last edit: 20 Feb 2014 05:13 by vlad_vy.
20 Feb 2014 09:33 #20644
Yeah I saw that. I'm not sure how easy it will be to fix, but definitely a bug. I'll check it out.
- chris-nc
20 Feb 2014 15:56 #20651
by chris-nc
Awesome, thanks for the responses from everyone. I am very interested in being able to get good telemetry data (particularly since I purchased the TM1000 already). If there is anything I can do to assist (testing, etc.) just let me know. I appreciate the efforts.
Oh, and for what it's worth, RPM data would be good to keep in the list, as it is part of the basic TM1000 capability from Spektrum (and one I hope to use). At least for my Devo 10
Chris
Chris
- gdrekuc
20 Feb 2014 20:51 #20663
by gdrekuc
In my opinion holds and lost frames are more important than fades and it will be interesting to have them showed on the main screen. As fades occur frecuently they are not much of a concern, but 30 o more lost or 1 hold frame after a flight requires an immediate action. During the flight an erratic atttitude cause can be found just peeking the main screen looking for holds...
Gus
Gus
21 Feb 2014 03:17 - 21 Feb 2014 03:18 #20674
For me, it has not big sense to support Tx (Devo7e), that limit features for all others Tx. At least full support. For now DSM2/X protocol has not future for evolution, as it limited by Devo7e. The same thing has place for other features and protocols. Bad thing for project evolution.
Last edit: 21 Feb 2014 03:18 by vlad_vy.
- WheresWaldo
21 Feb 2014 03:52 #20676
by WheresWaldo
Agree 100%, the 7e should be a subset of what is possible with deviation and not the standard.vlad_vy wrote: For me, it has not big sense to support Tx (Devo7e), that limit features for all others Tx. At least full support. For now DSM2/X protocol has not future for evolution, as it limited by Devo7e. The same thing has place for other features and protocols. Bad thing for project evolution.
21 Feb 2014 04:21 #20680
Another way to look at it is that most Deviation development is limited by my availability and interest in working on any given task.
For the most part the things that get done fastest are the things other people do the development for.
- chris-nc
28 Feb 2014 01:15 #20943
by chris-nc
So I'm just checking back in on this thread to see if there are any ideas on a resolution? While I have some basic coding skills, there is no way I can contribute, but I completely understand the effort involved. Is there a contributing programmer that may be able to issue a fix for at least having the option of the 'temp' parameter added to the list of items available to display on the main screen (preferably in a box)?
28 Feb 2014 03:14 #20946
code fix was already released to the nightly builds.
- chris-nc
28 Feb 2014 12:55 #20957
by chris-nc
Thanks PB. I appreciate the quick response.
I guess my next question is: is there any reason to be concerned with the stability of the nightly build releases? Would hate to lose my 500X to glitch.
- WheresWaldo
28 Feb 2014 14:05 #20963
by WheresWaldo
chris_nc, I use every nightly plus some of the stuff sbsntp adds in my Devo10. I also added the nrf24L01 module to fly my HiSky micro. The only glitch I have ever had while flying is the ones from my brain to my thumbs.
I also have a Trex500 clone and as soon as I get my gyro will be adding a CopterX CX250SES.
- chris-nc
28 Feb 2014 14:21 #20965
by chris-nc
Hey thanks Waldo. I appreciate the feedback. I'll grab the nightly and do some testing with my other heli's as well.
I'm also using a Devo 10.
Time to create page: 0.208 seconds
- telemetry temp on main screen?
