permanent timer limited to 99h
07 Mar 2014 15:05 - 07 Mar 2014 15:19 #21345 by linux-user
permanent timer limited to 99h was created by linux-user
A user from the german RCline forum would like to have permanent timer up to 999h ;)
Reason is, he has 2 CP Helis (GeniusV2/SP126) with over 100h flight time, and one (NewV120D02S) which will soon reach the 99h limit :blink:
Is there an easy way to increase the limit of the permanent timer?
Last edit: 07 Mar 2014 15:19 by linux-user.
10 Mar 2014 13:15 - 10 Mar 2014 13:17 #21416 by Exbird
Replied by Exbird on topic permanent timer limited to 99h
no way, no answer??? :( where are the specialist? :)
please help, if you can B)
thanks
oh, sorry - i use Devo8s :whistle:
Last edit: 10 Mar 2014 13:17 by Exbird.
10 Mar 2014 17:25 #21425 by IMback!
Replied by IMback! on topic permanent timer limited to 99h
Thats a serious heli addiction :cheer: . Come to think of it my WNCPX is nearing 50h so it will hit the limit kinda soon too :whistle:. i havent looked at the implementation but it should not be too hard to change it to 999h.
10 Mar 2014 20:07 - 10 Mar 2014 20:11 #21431 by Exbird
yes, it is B)
since June 18th i start to fly cp-heli
today i`m around 420h
GeniusCP v2 - more than 120h
SP 126 - 108h
V120D02S - 78h
the rest - fp-helis - Quadrocopter........
i know - i`m a crazy :whistle: musician
Last edit: 10 Mar 2014 20:11 by Exbird.
10 Mar 2014 23:09 #21436 by PhracturedBlue
Replied by PhracturedBlue on topic permanent timer limited to 99h
I looked into it. The maximum value is ~596hrs without significantly reworking the timer code. That is a pretty random number so I thought about limiting it to 499hrs. However, the box cannot hold a value that large, and that would mean I need to write some custom code to display a really large value. I don't think there is sufficient ROI to spend the effort on that.
11 Mar 2014 05:21 #21447 by FDR
Replied by FDR on topic permanent timer limited to 99h
I would cut the seconds, when the time is too large to display...
11 Mar 2014 07:22 #21449 by Exbird
@ PhracturedBlue
if it`s too complex, please no extra work - the current timer is perfect:)
i have my accu-list to see how much cycle one accu works for each heli -
so i proper see the time i fly with it :)
and thanks for your wonderful Firmware - i love it
Time to create page: 0.290 seconds
