Binding issues with nRF24L01+
15 Mar 2014 15:26 #21565 by hogan
Binding issues with nRF24L01+ was created by hogan
I installed this module www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
in my devo 7e. Modified the tx file in notepad++. Already have the A7105 ( running great). Followed daryoons webpage and when I attempted to bind it with the FBL70, the servos did their typical thing in resetting and then nothing. The light on the heli was rapidly flashing but couldn't do anything.
My V911's, MSRx, and Ladybird still bind and fly.
any ideas?
16 Mar 2014 00:36 #21579 by blackmoon
Replied by blackmoon on topic Binding issues with nRF24L01+
Please post your deviation build revision, your model file, hardware.ini file.
Modules are no longer enabled in the tx.ini file.
Thanks.
16 Mar 2014 13:44 - 16 Mar 2014 13:44 #21586 by hogan
Replied by hogan on topic Binding issues with nRF24L01+
Running V4.0.1
Tx file and the 3 model files I have.
models 6 and 7 are FBL70
model 9 is the V944
Last edit: 16 Mar 2014 13:44 by hogan.
16 Mar 2014 14:00 #21587 by PhracturedBlue
Replied by PhracturedBlue on topic Binding issues with nRF24L01+
don't see anything obvious wrong with your tx.ini or your model file. Can you take pictures of your module install to ensure it is wired properly?
16 Mar 2014 16:51 - 16 Mar 2014 17:01 #21593 by hogan
second pic is both A7105 module and nRF module together. The PCB on the Tx
the wires are heatshrinked to the module so a photo would not be useful but it is identical to the photo in hack mod page.
TMS yellow wire goes to A7105 module, TCK yellow wire goes to nRF module.
VDD has both wires to the modules including a pink from the MISO from the nRF
Last edit: 16 Mar 2014 17:01 by hogan.
16 Mar 2014 17:40 #21594 by PhracturedBlue
MISO of the nRF module should be connected to MISO of the CYRF module.
CE of the nRF module should be connected to VDD.
16 Mar 2014 17:57 - 16 Mar 2014 23:41 #21595 by hogan
I think they are.
The VCC(red wire) and CE (pink) wire are together with the red 3.3v from the A7105. There are 3 wire going to the VDD.
The MISO on the nRF is attached to the 4th pin from left, well from the right as well.
Last edit: 16 Mar 2014 23:41 by hogan.
17 Mar 2014 19:27 #21623 by hogan
I just double checked the wires and they seem to be correct. I knew the A7105 module went too easy!
18 Mar 2014 01:04 #21636 by hogan
Got them working.
1- I put a small piece of electric tape between each of the wires going to the Tx board.
2- The FBL70's were not on the HISKY protocol on the Tx. One was on PPM and the other was on NONE.
3- When experimenting, make sure the main motor is UNPLUGED! Found out the hard way that the throttle was reversed and up she went like a scared rabbit. Nearly took my head off!!
All I have left is to figure it out to work with Phoenix and will be back down to 1 Tx!
Thanks to all who tried to help.
Time to create page: 0.208 seconds
