WL Toys V912
17 Mar 2014 00:20 - 17 Mar 2014 00:22 #21605 by Dandan123
WL Toys V912 was created by Dandan123
The new V912 came with a new board with support to video and other things like water cannon, rocket luncher. I would like to use my Devo 12s to active this accessories, but I couldn't. Tried to use channel 5,6, 7 with no help. I have tried use WLToys V9x9 protocol without success too. Anyone has a idea? thanks. I'm sorry for the bad english.
PS. Add pictures of the board and rocket launcher.
Last edit: 17 Mar 2014 00:22 by Dandan123.
03 May 2014 07:09 #22857 by jegaoca
Replied by jegaoca on topic WL Toys V912
Good morning,
I'm in the same situation. I have tried from channel 5 to 8 without success. In Idle channel monitoring me recognizes keystrokes and output channels, but the only thing that does is speed when control signal to channel 7.
I Deviation Devo 7e with 4.0.1 + V912 + missile launch.
Maybe someone has the solution-
Sorry for my English.
A greeting.
03 May 2014 08:24 #22858 by SeByDocKy
Replied by SeByDocKy on topic WL Toys V912
Well, I guess these extra channels are not taken into account....
These channels should be sniffed to add into the protocol. Maybe I have a new V912/V913 TX. So I have time I can sniff this packet with Logic Analyser 1.1.15. Maybe Hexfet, Victzh or PB can update the FlySly protocol.
04 May 2014 08:27 #22871 by jegaoca
Thanks for answering, SeByDocKy.
We will wait, if possible, in the future we could use these new V912 accessories.
Maybe the experts do not have time for such things as they will have more important things to update.
Anyway thanks and congratulations for the great work that is being done in this project.
A greeting.
07 May 2014 02:51 #22955 by jegaoca
Hello, SeByDocKy. Communicate it would be great if the results of that test you mention. Regards
01 Jul 2014 06:53 #24319 by jegaoca
Hello SeByDocKy. I still can not find solution to the channel settings for missile launches and other accessories for the new V912. You've made some progress? A greeting.
01 Jul 2014 09:06 #24321 by SeByDocKy
jegaoca wrote: Hello SeByDocKy. I still can not find solution to the channel settings for missile launches and other accessories for the new V912. You've made some progress? A greeting.
I looked into the FlySky protocol file:
if (Model.proto_opts[PROTOOPTS_WLTOYS] == WLTOYS_ON) {
        if(Channels[4] > 0)
            packet[12] |= 0x20;
        if(Channels[5] > 0)
            packet[10] |= 0x40;
        if(Channels[6] > 0)
            packet[10] |= 0x80;
        if(Channels[7] > 0)
            packet[12] |= 0x10;
Did you tried to setup a config file using the WLtoys option ? and as you can see Channel 5 to 8 are used. So maybe assign the Hold button to one of these channel
04 Jul 2014 17:50 #24384 by jegaoca
Hello.
As you get to see the flysky.mod file?
11 Aug 2014 14:46 #25144 by jegaoca
I just want to know if it is possible and if so is. How do you do it? Buy several accessories, and including missile launches and I can not use. Someone who wants to help you answer please.
22 Aug 2014 17:57 #25351 by mwm
Replied by mwm on topic WL Toys V912
jegaoca wrote: I just want to know if it is possible and if so is. How do you do it? Buy several accessories, and including missile launches and I can not use. Someone who wants to help you answer please.
Did you ever get this working?
I had those things on the v959 working. If you don't have the v912 working yet, can you try a v959 with your Tx? Also, can you upload the appropriate model.ini file for us to look at?
23 Aug 2014 12:08 #25359 by jegaoca
Thanks for your interest. I've tried everything with channels 5 to 8 without success. The V912 has flysky protocol. know where I can get a model.ini you can try as you say. maybe that's a good way to success.
23 Aug 2014 22:16 #25375 by mwm
Well, here's my v959 model.ini file to try. Last time I checked, it had three of the four functions working. Based on the code posted by SebyDocky, all four might be available now.
ELE DR -> turns on leds
MIX0 -> Secondary button
MIX2 -> Primary button
FLIP wasn't working before, but might be enabled by FMODE1.
If this doesn't work, it would help a lot to see the model.ini file you've already tried.
24 Aug 2014 08:26 #25376 by billmester
Replied by billmester on topic WL Toys V912
FLIP?
On a V912?
wow...
24 Aug 2014 09:39 #25377 by jegaoca
billmester wrote: FLIP?
On a V912?
wow...
Goodmorning, billmester.
We talk about missile launcher.
24 Aug 2014 09:42 #25378 by jegaoca
mwm wrote: Well, here's my v959 model.ini file to try. Last time I checked, it had three of the four functions working. Based on the code posted by SebyDocky, all four might be available now.
Thanks for the file.
I have tried it and it doesn't work.
I will go on trying it.
Thanks for your help.
26 Aug 2014 02:41 #25395 by mwm
Odd. I just copied it to a v915 (supposedly very similar to the v912) and things worked, kind of. I can control the lights, and the "high gain" feature, though that also kicks the throttle into high, which it shouldn't do. There aren't any other features.
Do these things work with the stock transmitter? How about a v959 transmitter?
I'm going to be blunt here. If you want help with these, you really need to cooperate with the people trying to help you. I've asked you for your model file twice, with no response. You don't answer the questions from people trying to help you. This makes people just give up on helping you. If I hadn't had the v915 show up, I would have.
03 Sep 2014 06:07 #25477 by jegaoca
Thank you.mwm
as far as I can see, I have been reading subforums at the problem, he flysky protocol v202 while working everything: missile launch, camera, water guns and so on… I imagine there will be to wait for updates of genius flysky protocol and it tells us how the channels form of 6 to 8.
and a hello, thanks for your concern. have a nice day.
Time to create page: 0.207 seconds
