2.4 Transmission on Devo 6S
27 Mar 2014 20:52 - 27 Mar 2014 20:53 #21897 by whereisbenny
2.4 Transmission on Devo 6S was created by whereisbenny
Hi all
I have a devo 6S that i use with UHF via the training port, i am wanting to disable the 2.4 transmission so that i dont get any possible interference on my fpv video link which is also 2.4
is there a simple mod i can do to stop any sort of transmision?
Cheers
Last edit: 27 Mar 2014 20:53 by whereisbenny.
06 Apr 2014 03:29 #22161 by esklarski
Replied by esklarski on topic 2.4 Transmission on Devo 6S
As far as I know there is no such feature, your best bet is to turn down the transmit power to the lowest setting. I do this when I'm configuring mixers to save battery.
To those with the power, a tx power of 0 or off would be great as a feature.
06 Apr 2014 04:39 #22162 by PhracturedBlue
Replied by PhracturedBlue on topic 2.4 Transmission on Devo 6S
If you are using Deviation and the PPM output, it will not transmit on 2.4GHz at the same time. I believe this is likely the same for the stock firmware, thoughI have never verified it.
07 Apr 2014 02:55 #22186 by anarchy
Replied by anarchy on topic 2.4 Transmission on Devo 6S
if your having problems with signal on fpv 2.4 is crowded signal and suffers allot you should look at 2.4 mushroom antenna on both ends
