devo 7e start to finish mods help ??????
08 Apr 2014 07:31 - 08 Apr 2014 16:38 #22237 by anarchy
ok so i have failed once and am going to start over i have confidence that this will go better i failed at the hardest part the range mod shaky hands lol
womp womp womp
OK SO THIS IS WHAT I WOULD LIKE AND YOUR HELP WOULD BE WONDERFULL
I WOULD LIKE YOU TO HELP ME AS I MAKE A START TO FINISH MOD GUIDE FOR THE 7E THAT IS CURRENT AS POSSIBLE SO I WANT TO KNOW THE RIGHT ANSWERS LOL
WHAT ORDER SHOULD THIS ALL BE DONE IS A MUST I AM NOT CLEAR ON EITER
OK SO WE HAVE THE SWITCH MOD I HAVE TWO THREE WAY SWITCHES SITTING HERE NOW I THINK THIS SHOULD BE DONE FIRST BEFOR FIRMWARE OR ANYTHING ELSE MAY BE WRONG ANY HELPFULL LINKS TO ADDING THESE AND WHAT FIRMWARE IS RUNNING GOOD FOR THIS WOULD BE HELPFULL
NEXT I HAVE A WL TOYS A7105 MODULE I THINK THIS COMES AFTER FIRMWARE MOD I HAVE DONE THIS AND HAD WORKING BUT HAVE SEEN DIFFRENT WAY TO DO IT SO PROPER PIC LINK OR PICS WOULD BE GREAT ALSO ANY LINKS TO CURRENT OR CORECT MOD TUTORIAL WOULD BE GREAT
NOW THE RANGE MOD SCARRY PICTURES THAT YOU CAN SEE IT IN DONT GIVE YOU AN IDEA HOW TINY IT REALLY IS SO MY IDEA FOR THIS IS TO PULL COVER AND TAKE CONDUTIVE PEN AND JUST CONECT THE SOLDER ALONG THE SIDE OF THE DIODE WILL TNIS WORK WITH OUT REMOVEING THE DIODE I WOULD LIKE TO AVOID GETTING MY IRON IN THIS AREGETTING TO IT IS NO PROBLEM I WILL SHOW MY METHOD WHEN I DO IT AGAING
OK WELL THAT IS WHAT I WOULD LIKE IF EVERY ONE CHIPS IN THEN IN ABOUT 4 DAYS I WILL START TO MAKE A VIDEO TUTT OF THE WHOLE PROCESS FROM BEGING TO END THANKS IN ADVANCE FOR ANY AND ALL HELP
UPDATE I ORDERED A 8S UPGRADE MODULE FOR MY OLD 7E SO I AM GONNA DO TWO UNITS AND NEED A TUTT ON THE 7E WITH THE 8S 12S MODULE IF ANY ONE KNOWS WHERE ONE IS
Last edit: 08 Apr 2014 16:38 by anarchy.
Time to create page: 0.044 seconds
