cant go back to Devo 7E firmware
- Torch
31 May 2014 13:03 #23784
by Torch
cant go back to Devo 7E firmware was created by Torch
Not able to go back to Devo 7e firmware. Please help it would boot iup throttle stick. I tried to upgrade it back to v2 devo 7e. Do i need to upgrade.dfu and library?
31 May 2014 14:23 #23788
Replied by PhracturedBlue on topic cant go back to Devo 7E firmware
you need to 'Upgrade' the lib and firmware to the proper version from Walkera's site. That is all there is to it.
- Torch
01 Jun 2014 03:37 #23802
by Torch
Replied by Torch on topic cant go back to Devo 7E firmware
Got it thank you. Here are steps:
1. Use DfuSe Upgrage Tool and Upgrade (Devo7E v2 latest or stock firmware goto to www.walkera\upload\radio\devo7e and download devo7e.zip).
2. After updating back to Devo Firmware, run updates on Library.
I thought it didn't work because when I boot up the TX it stuck on window "Throttle Stick". Then I realized that the walkera firmware always flash back to mode 1 and naturally my right stick is at midstick. I push down the right stick and Devo software comes up. I go and change stick mode to mode 2.
Now I can go back to Devo 7E if needed. I really like Dexiation but can't get my Ladybird to get to 3-axis.
Time to create page: 0.070 seconds
- cant go back to Devo 7E firmware
