4.0.1 DSM Temp telemery?
26 Jun 2014 01:54 #24250 by mwm
4.0.1 DSM Temp telemery? was created by mwm
I just added a TM1100 to my DSM2 quad in order to get voltage feedback. The telemetry monitor seems to be working as well as expected - Battery & Rx voltages and temperature all display. No Rx info, as the Rx has no data port. I've set and tested the alarms for battery voltage, and they work fine, so I got what I wanted.
However, I'd also like to set an alarm for temperature. After all, it's there. But when I select Temp in the telemetry settings, I can't change the value. It's stuck at "---".
Bug? Fixed in nightlies? Any suggestions?
Thanks,
Mike
26 Jun 2014 03:19 - 26 Jun 2014 03:21 #24253 by vlad_vy
Replied by vlad_vy on topic 4.0.1 DSM Temp telemery?
Seems it's a bug. With v4.0.1 emulator I can't change Temp value. With nigtly build I can set Temp value.
Last edit: 26 Jun 2014 03:21 by vlad_vy.
26 Jun 2014 15:20 #24257 by mwm
Replied by mwm on topic 4.0.1 DSM Temp telemery?
Thanks for the confirmation.
If you're running the nightly, can you tell me if more telemetry data is available for putting in display boxes on it? I'm thinking about adding altitude, but can't do it on 4.0.1.
Time to create page: 0.251 seconds
