Devo 12S DSMX Range and Telemetry Questions
27 Mar 2015 21:14 #30341 by aMax
Thomas.Heiss wrote: @aMax: Wrong DL address.
Indigo test rls for telemetry: bitbucket.org/Indigo1/deviation/downloads
Version as of 03/26: 72057cf
Post #30306......
That´s the one I already tested and the noise detected .
Therefore Indigo advised me to test the recent nightly builds.
28 Mar 2015 07:33 #30351 by Indigo
Replied by Indigo on topic Devo 12S DSMX Range and Telemetry Questions
Thank you aMax. Some change I've made must be causing this noise problem. :sick:
Please let me know if this problem is still there in new version c810bb4 available here:
28 Mar 2015 07:43 - 28 Mar 2015 09:27 #30352 by Indigo
Wene001 wrote: i think indigos patches are at the moment not in the team nightlies
Yes, that is correct. We need to first make sure there are no problems before we add this Telemetry update to team nightlies.
FYI: I did a merge with team nightly 2015-03-24 before publishing these recent test builds so it will have all but the most recent updates.
B)
Last edit: 28 Mar 2015 09:27 by Indigo.
28 Mar 2015 13:04 - 28 Mar 2015 14:24 #30360 by aMax
Just flashed and NO noise.
Will test a little more later on.
EDIT: Range (dsm2/x with park rx RX615X)) is good as the day before yesterday.
100uW >8m> kitchen/livingroom(double wall).
Even from upstairs, same distance, through the congrete floor at 45 degree
angle, while at the devo the range test is activ.
Impressiv.
What I have to remark, the antenna is always well-positioned at its best radiation pattern.... ;)
Last edit: 28 Mar 2015 14:24 by aMax.
28 Mar 2015 17:44 - 28 Mar 2015 17:48 #30376 by djsmeegy
Replied by djsmeegy on topic Devo 12S DSMX Range and Telemetry Questions
Hi guys, I have DEVO 10 w/ deviation 4.0.1, I have done no mods with my TX. I downloaded Indigo's latest fw and read the file UPDATING.md, there's written: "If you haven't modded your transmitter, this shouldn't be an issue".
I have not been using any nightly builds yet so I have not modded my TX as well, but Im considering to use improved Indigo's fw due to increased range and telemetry fix.
As I mentioned before Im gonna to buy 700 class heli and I would like to use my amazing DEVO 10 TX, but what should I do to be albe to flash Indigo's fw and what about the file system in my TX? (Im sorry it's little bit out of topic, but Im quite confused and don't know where to look).
Thank you, fellows :)
P.S. Im gonna to buy Devo 12, so your advice will help me with it as well.
Last edit: 28 Mar 2015 17:48 by djsmeegy.
28 Mar 2015 18:24 - 28 Mar 2015 18:25 #30378 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 12S DSMX Range and Telemetry Questions
If you aren't confident using a nightly build I really recommend you wait for an official release. Especially when considering the size of a 700 scale heli. These are still experimental builds. I expect we will do a new release reasonably soon. There are a large number of changes in the current builds compared to 4.0.1. most of them are not well documented yet. These changes have not yet been reviewed and incorporated (not that I doubt they will be) either.
I urge real caution when using anything other than official releases with anything with enough power to do significant bodily or structural harm.
This thread's purpose is debug and verification of new changes. If you need help setting up or installing, or choosing a Tx, a separate thread is a better place for it.
Last edit: 28 Mar 2015 18:25 by PhracturedBlue.
29 Mar 2015 09:18 #30395 by McQuack
Replied by McQuack on topic Devo 12S DSMX Range and Telemetry Questions
And then? It's the problem fixing? ;) Now we can have a full range or still having a radio for toys? :dry:
29 Mar 2015 10:01 #30396 by FDR
That was a nice first post... :(
29 Mar 2015 10:47 #30397 by McQuack
FDR wrote: That was a nice first post... :(
:P :P :blush: Sorry I didn't like to sound unpolity, all of you have my respect and admiration, because I know than this is not easy and there are a lot of work behind a new update for ours radios, but I change all my helis to DSMX and sold my other radio and just have a 12S I really interesting in this Topic, because in this way I won't fly them. ;)
29 Mar 2015 11:56 #30399 by MacGyverek
Replied by MacGyverek on topic Devo 12S DSMX Range and Telemetry Questions
When you will start final testing for new official build? Do you have any roadmap for final version?
29 Mar 2015 13:24 #30400 by PhracturedBlue
Please take the discussion here:
www.deviationtx.com/forum/7-development/...xt-deviation-release
and leave this thread for discussion of testing Indigo's fixes
30 Mar 2015 12:35 #30453 by linux-user
Replied by linux-user on topic Devo 12S DSMX Range and Telemetry Questions
badfrogg wrote: What can i do to help. I have a:
Devo 7e with range mod Tested to over 1000ft I will flash with your current firmware.
I have a Spektrum 6210 Rx (DSMX)
Spektrum 6200 Rx (DSM2)
Lemon DSM2
and some OrangeRx R110X DSMX Sats.
I could put them in my biggest plane as just payload and bound to the devo and fly the plane with my Taranis as far out as i can and then check the led's on return.
whatever you are doing: Try to create a reproducible test environment!
So that you can report whether things have
- improved,
- got worse, or
- stayed the same
03 Apr 2015 03:48 - 03 Apr 2015 03:49 #30726 by Cesco2
Replied by Cesco2 on topic Devo 12S DSMX Range and Telemetry Questions
linux-user wrote: whatever you are doing: Try to create a reproducible test environment!
Fully agree. Not an easy thing to do, and indoors its almost impossible.
Go outside to do range measurements. Even outside you may get different results depending on humidity, vegetation and car traffic. Indoors you get rubbish results.
My range experiments did show you need up to 500m distance to test dsm2 / dsmx radios. Dsm2 or dsmx had the same range. Devo and original radios had about the same range when corrected for output power. Non-obstacle caused dropouts start at 200m.
Frsky doesent show any weakness at my maximum test distance of 800m. I have to firmly grab the antennas with both hands to make it fail. I havent tested futaba yet, i expect it to be on par with frsky. Flysky seems to be slightly inferior to frsky but much better than dsm.
Conclusion of my range tests is DSM2 and DSMX sucks. I did 3 different type of orangerx receivers. First signal loss occurs 20m behind the house, then 60m behind some vegetation, then intermittant operation from 200m to 500m. None of the other brands does have this problems. Frsky is rock solid at 800m and doesent bother about a house or some vegetation.
Last edit: 03 Apr 2015 03:49 by Cesco2.
03 Apr 2015 10:46 #30740 by McQuack
Impressiv.
Hello Cesco I'd like to ask you what is the version than you are trying, the last one mod for testing by Indigo?
OMG Finally I will see myself buying a Futaba 14SG....and I don't want but selling all my DSMX and my love 12S :unsure:
04 Apr 2015 18:09 - 04 Apr 2015 18:38 #30795 by linux-user
Hi Cesco2,
very enlightening post.
Thank you.
Could you tell us some more details
Cesco2 wrote: Devo and original radios had about the same range when corrected for output power. Non-obstacle caused dropouts start at 200m.
Do you mean genuine Spektrum TX and DSMX on deviation have the same range?
Cesco2 wrote: Frsky doesent show any weakness at my maximum test distance of 800m.
Frsky with deviation and some CC2500 module or Taranis?
Cesco2 wrote: Conclusion of my range tests is DSM2 and DSMX sucks.
Which combination have you tested? Coud you name the exact version?
deviation <-> genuine Spektrum RX?
deviation <-> orange/Lemon?
Spektrum TX <-> genuine Spektrum RX?
Spektrum TX <-> orange/Lemon RX?
orange TX <-> orange/Lemon RX?
BTW:
The test method, this guy uses in his video is very revealing.
Range is good reliability is better
Last edit: 04 Apr 2015 18:38 by linux-user.
06 Apr 2015 15:45 - 06 Apr 2015 15:54 #30844 by Cesco2
linux-user wrote: Do you mean genuine Spektrum TX and DSMX on deviation have the same range?
I dont have any genuine spektrum gear. I have the orangerx T-SIX. Corrected for output power the T-SIX and deviationtx have the same range (T-SIX has 158mw, devo has 65mw). Deviationtx range on dsm2 and dsmx was the same.
linux-user wrote: Frsky with deviation and some CC2500 module or Taranis?
Aurora9 with genuine frsky module (old stuff).
linux-user wrote: Which combination have you tested? Coud you name the exact version?
deviation <-> orange RX
orange TX <-> orange RX (R615, R620, R800X)
What i have seen is enough for me, but in no way bulletproof or scientific.
One problem is you cant test a bunch of receivers together as the telemetry output deafens the other receivers. Dsm2/x will fail whenever a frsky or flysky 2way receiver is near.
Planned tests (i have the hardware):
Devo in devo mode with walkera rx
orangerx tx module (dsm2 + dsmx)
Tests i dont have the hardware:
Spektrum tx - orangerx
Planned tests needing extended distance (i have the hardware):
Frsk tx module
Flysky 2way
Taranis
Futaba fasst / fasstest
Graupner hott (mx12)
Last edit: 06 Apr 2015 15:54 by Cesco2.
07 Apr 2015 16:34 #30878 by gdrekuc
Replied by gdrekuc on topic Devo 12S DSMX Range and Telemetry Questions
Hi, as I had a range problem with my Goblin 770 using Spektrum DSMX original satellites and a TM1000 with a DEVO12S of course, I am very interested to give some help testing this fix.
I already have:
- Devo12S
- Spektrum DX7s
- RX1201
- Walkera Telemetry module
- Spektrum TM1000 Telemetry module
- Original Spektrum satellites
- AR8000
- AR6100e
- Orange DSMX satellites
- IKON (if necessary I can do range tests with DSMX sattellites attached)
- k-bar (same as IKON)
Anybody knows how much power uses a spektrum transmitter in range test mode? Having that info, I can perform a direct comparison.
Indigo: Could I use the last version in your repository (deviation-devo12-v4.0.1-5c8744e.zip) to perform the tests?
07 Apr 2015 16:43 #30879 by vlad_vy
Replied by vlad_vy on topic Devo 12S DSMX Range and Telemetry Questions
Spektrum has -30dB range test,
JR JR12X has -27dB range test and
Futaba T14SG has -20dB range test.
-30dB = 1000 times less power = 31.6 times less range
07 Apr 2015 17:22 #30880 by gdrekuc
Ok, but how much power should I configure the devo 12s to match the same power than the spektrum in range test (-30db)? I am not sure if setting the devo to 0.1mw would be the same...
07 Apr 2015 17:41 #30881 by vlad_vy
Set to lowest power 100uW
Time to create page: 0.197 seconds
