Devo 12S DSMX Range and Telemetry Questions
30 Jan 2015 11:38 #28237 by cmpang
Replied by cmpang on topic Devo 12S DSMX Range and Telemetry Questions
best is to have separate builds for telemetry/no telemetry application. A robust radio control link is most important that any other feature should give way to...
30 Jan 2015 11:44 #28238 by Indigo
Replied by Indigo on topic Devo 12S DSMX Range and Telemetry Questions
Thank you linux-user and vlad_vy for explaining that line of code. :)
30 Jan 2015 12:08 - 30 Jan 2015 12:09 #28240 by vlad_vy
Replied by vlad_vy on topic Devo 12S DSMX Range and Telemetry Questions
static void parse_telemetry_packet()
    const u8 *update = NULL;
    if (update) {
        while(*update) {
            TELEMETRY_SetUpdated(*update++);
What will do this code if *update = NULL and we have not any telemetry data? What will be the value 'update'?
Last edit: 30 Jan 2015 12:09 by vlad_vy.
30 Jan 2015 12:14 - 30 Jan 2015 12:14 #28241 by vlad_vy
    if (update) {
        while(*update) {
E.g TELEMETRY=ON and we have not telemetry unit.
What will do this code if we have not any telemetry data? What will be the value 'update'?
Last edit: 30 Jan 2015 12:14 by vlad_vy.
05 Feb 2015 01:12 #28404 by SM510
Hi, i'm new my english is not the best, and dont know if its the rigth topik, so sorry but had the sam prolems with range at vbar with tow satelites and devo 8s. i taked this last sulution and everithing works fine (DSMX), but now i insalled a tm1000 (pin out the data cabel, no backup lipo) and now jups the display for volage 1 everytime from 7,4v (BEC) to 24v (Lipo) in voltage 2 nithing happens 0v. i hav try reinstall the update, one groundline for all, rebind without sensor and and and... now is my question is it posebil that its somthing rong with the telmetie protokol, or ist my mistake :oops:
my setup
Goblin 500
2 new generation dsmx satelites
Vbar 5.3pro bind on 22ms
hobbywing platinum v3 100
tm1000 with volta and tempratur sensor
Devo 8s v4.0.1-22961b6
07 Feb 2015 13:38 - 07 Feb 2015 13:39 #28433 by cmpang
Indigo wrote: I'm currently working on DSMX Telemetry problems with Thomas Heiss.
The problems are caused by data integrity issues in receiving telemetry data .
Deviation could also be transmitting occasional bad packets, so I have also added a fix for #594: Data integrity of Channels array
Anyway it would be good to have a number of people test this. Downloads are available here:
bitbucket.org/Indigo1/deviation/downloads
aMax wrote: hardware.c/2014-05-21/
Allow use of txid override on Devo7e. Devo7e will always be in telemetry mode now
Reversing that change (ie. Enabling On/Off for telemetry mode on Devo7e), makes the module file size too large (max size is 4KB). However, I found another way to reduce code size so Telemetry On/Off should now work. :P
I've done a through test on this build, running my r/c boat continuously for two hours in the pond I used to played, with my usual test setting on 3mW Tx output, without any problem. That results that the DSMX protocol with Telemetry OFF is NOW on par (if not better) with my trusty Devo protocol. The amber light did flash at times, but no data link lost as shown my the red led for the whole two hours testing period.
Previous readers may recall my Devo 7e with R601 works in range to 1Km..
So at this point, a big thanks to Indigo, and please confirm that nothing has been changed in the Devo part so that I can shift all my 7e (three sets) to this build for happy flying..
cmPang
Last edit: 07 Feb 2015 13:39 by cmpang.
07 Feb 2015 14:51 #28434 by aMax
The video where the quad was touching the power cable?
Impressive!
What about the tx side? Which antenna,.. any booster?
07 Feb 2015 15:27 #28435 by cmpang
external SMA external antenna, standard 2dB type. No power booster at that time.
To be exact, what I meant 3mW Tx output today is actually setting to 300uW in Deviation but becomes 3mW after the 10dB booster I fit recently..
Next time I will put the orange receiver sitting dummy inside one of my Devo control plane and see if any Red led flashing after landing..
cmPang
14 Feb 2015 06:27 #28662 by cmpang
I have tested DSMX working flawlessly with on this build. As it has fixed the bug in DSM protocol, will it be Incorporated into future nightly builds ?
Big thanks to Indigo anyway...
cmPang
15 Feb 2015 05:25 #28701 by Indigo
You're welcome, thanks for testing and providing feedback. :woohoo:
cmpang wrote: I have tested DSMX working flawlessly with on this build. As it has fixed the bug in DSM protocol, will it be Incorporated into future nightly builds ?
That's great. Did you use a recent build?
I changed a binding flag in the code about 4 days ago. It works for some people but not others. In next version just uploaded, I've added a 3rd option to DSM2/DSMX Telemetry config setting. For those who have binding problem with Telemetry "On", try changing setting from "On" to new "B2" option.
Either "On" or "B2" will work. Some models prefer one over the other. "B2" is the special case. Why did I call it "B2" I hear you ask? Believe it or not the size of the DSM2/DSMX protocol file on Devo7e is such a tight squeeze only 2 characters would fit, B2 is named after the binding code 0xb2.
I've also included in this build some important patches that will benefit Devo10/7e.
Yes, it will be included in nightly's soon. I will submit a pull request for this before I start working on displaying the new Telemetry values.
Enjoy!
15 Feb 2015 05:28 #28702 by cmpang
I use the builds from your posted link below:
cmPang
08 Mar 2015 10:05 - 09 Mar 2015 06:05 #29453 by Indigo
Telemetry Update for Devo & DSM protocols
Both Devo and DSM Telemetry are believed to now be working correctly
Download from:
Last edit: 09 Mar 2015 06:05 by Indigo.
09 Mar 2015 09:26 - 09 Mar 2015 10:11 #29481 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 12S DSMX Range and Telemetry Questions
vlad_vy wrote:
Indigo wrote: When binding, if protocol is DSMX and number of channels is 7 or less it sends a different code within the binding packet. Presumably to tell rx that telemetry data is not needed.
Not that case. If telemetry enabled, it send 0xB2, without that telemetry unit does not work with 6-7 channels Rx.
But, it can be problem for other Rx (e.g. 7200BX). For that case it sends 0xA2 if telemetry disabled.
Hi all,
had a first testing deviation-devo10-v4.0.1-c0b203a_v2.zip.
I tried to bind AR600 + AR6210 with TM1000 in DSMx mode.
On AR600 + AR6210 was successful with "B2". "ON" does not work as stated before.
ON AR8000 I was successfull with "ON" or "B2"
On 200QX I was successful with "ON".
Do you mind further explaining to me what options should be send on a bind for
- 7CH
- AR600
- AR6210
- AR8000 (will have to re-test bind)
> 8CH
either
- telemetry ON
- B2
- OFF
for old + new code?
My feeling is that I get confused about the "&&" combination in the code anyways.
I can't tell for sure at this time what valid possible option scenarios are.
Why does have a user even have to think about "Am I using a 6CH RX + telemetry...oh then I have to choose "B2" because it will NOT work with "ON"" or the user has to test out like me?
I had to re-read this thread just for this case :-)
You would also have to update the Wiki, Manual just tell users about when to use "B2".
If telemetry (TM1000) is bind related to 6CH I would suggest - if possible - to check RX channel numbers and use the right bind mode option (probably 0xb2 in that case).
What was the problem again?
That "0xb2" bind option does not work all the time for some (BNF) receivers?
I bound the AR600 (StrykerQ) with Telemetry "ON" with deviationTX-devo10-v4.0.1-92e1705 and it was working.
However it does NOT work with deviation-devo10-v4.0.1-c0b203a_v2.zip.
Bound AR8000 before with telemetry "ON" (92e1705), works again it c0b203a, even with "B2".
Found some bugs which I will add to the second DSM thread.
Greetings
Thomas
Old code:
    if(Model.protocol == PROTOCOL_DSMX) {
#ifdef MODULAR
        packet[12] = 0xb2;
#else
        packet[12] = num_channels < 8 && Model.proto_opts[PROTOOPTS_TELEMETRY] == TELEM_OFF ? 0xa2 : 0xb2;
#endif
    } else {
        packet[12] = num_channels < 8 ? 0x01 : 0x02;
New code
        packet[12] = num_channels < 8 && Model.proto_opts[PROTOOPTS_TELEMETRY] != TELEM_B2 ? 0xa2 : 0xb2;
    else
Diff
-#ifdef MODULAR
-        packet[12] = 0xb2;
-#else
-        packet[12] = num_channels < 8 && Model.proto_opts[PROTOOPTS_TELEMETRY] == TELEM_OFF ? 0xa2 : 0xb2;
-#endif
-    } else {
+    if(Model.protocol == PROTOCOL_DSMX)
+        packet[12] = num_channels < 8 && Model.proto_opts[PROTOOPTS_TELEMETRY] != TELEM_B2 ? 0xa2 : 0xb2;
+    else
Last edit: 09 Mar 2015 10:11 by Thomas.Heiss. Reason: updated because of further testing with AR600/AR6210 with "B2" (working)
09 Mar 2015 11:21 #29487 by Indigo
The manual will probably just say: "If Telemetry 'ON' setting doesn't work, try 'B2'".
The ON setting will use code B2 when number of channels is 8 or more; and when less will use code A2. The 'B2' option forces use of code B2.
AR8000 is 8ch so settings ON and B2 are the same.
The 'B2' setting only has effect when protocol is DSMX and number of channels < 8. Otherwise 'B2' is the same as 'ON'. Making the user interface only show the 'B2' option when it is different to 'ON' adds 44 bytes to firmware size.
&& is logical AND
& is bitwise AND
12 Mar 2015 09:17 #29590 by johnho100
Replied by johnho100 on topic Devo 12S DSMX Range and Telemetry Questions
Hi everyone,
I originally started this tread last year because I was having range issues with my Devo 12S with the DSMX protocol. I have not came back for a while and it looks like things have changed thanks to Indigo and Thomas Heiss. It would be great if I can trust my Devo 12S and fly my larger helis!
Just a couple of questions:
1.) The DSMX range / reception problem I experienced was due to a telemetry code issue? Indigo's latest build has addressed this range issue?
2.) If I had my telemetry turned off, I wouldn't experience the range issue and achieve satisfactory range test results (with deviation 4.0.1)?
Thanks.
15 Mar 2015 13:22 #29735 by Indigo
Hi, I've tried to reproduce the DSMX range / reception problem you had, with deiavtion 4.0.1, August nightly v4.0.1-92e1705 and with latest Telemetry update.
Telemetry ON or OFF; DSM2 or DSMX; I have no measurable difference in range on any version.
15 Mar 2015 14:41 #29741 by aMax
@Indigo
Which rx did you use and how many channels are setup at the tx?
15 Mar 2015 14:48 #29742 by Indigo
I have Devo10 with model set to 7 channels.
15 Mar 2015 14:56 #29744 by Indigo
cmpang wrote: Another test with telemetry ON. Surprisingly, get the same result as with telemetry OFF above.
So would Indigo please comment, or other than get the switching function to work, you have also fixed some coding regarding telemetry?
cmPang
About my Telemetry update.
Before transmit and receive (Telemetry) were sharing the same buffer. This effected Telemtry where sometimes all values change at same time and display wrong values (Tx data overwriting telemetry). If the reverse ever occurred it would cause a loss of binding. To fix this I gave Telemetry a separate buffer.
I have also done the same for Devo Telemetry, but there must still be another problem because with Devo Telemetry the problem persists. I read somewhere that the CYRF6936 will lock-up if an attempt to transmit occurs too soon after receiving data. Such a lock-up would persist until protocol is reset which would explain why Devo won't bind automatically after being left on for some time.
17 Mar 2015 19:07 - 18 Mar 2015 11:45 #29784 by Cesco2
Replied by Cesco2 on topic Devo 12S DSMX Range and Telemetry Questions
I have range issues with Devo12S too. Sucks, because i like the radio.
Output power is 85mw on the 150mw setting (immersionrc meter) and surface range is around 250m with dsm2 or dsmx setting, 7 channels, no telemetry.
The Devo10 has 60mw output, 150mw setting, dsm2, 7 channel.
My other dsm2 transmitter, orangerx T-SIX does 130mw output and range is somewhat better, up to 500m. My orangerx TX module does a whopping 158mw, range not tested.
Frsky and Flysky radios have a rock stable signal at 760m distance. TX power is 60mw only. Is dsm2 / dsmx really that bad?
Edit:
since both the walkera modules output less that the stated 150mw i went searching. The PA is the RDTA212 chip, well capable of 20dbm (100mw). The thing other hf modules dont have is the little filter chip in the output. Seems a 2.4G bandpass filter CAN HAVE A 3DB INSERTION LOSS ( www.mouser.com/pdfdocs/TDKRF-3.pdf )
Last edit: 18 Mar 2015 11:45 by Cesco2.
Time to create page: 0.204 seconds
