Devo 10 dun bind
08 Jul 2014 08:51 #24467 by joeclone
Devo 10 dun bind was created by joeclone
I dropped my Devo 10 and now it dun bind with any of my models and there's no display on the lcd. I've removed the rear cover to check for loose connections and all looks ok. I've tried reflashing Deviation fw and reloading my model files and didn't help.
I can still go into update mode and usb mode but nothing else.
What others could I check for? Is there a way to reset the internal memory or something?
08 Jul 2014 23:45 #24478 by joeclone
Replied by joeclone on topic Devo 10 dun bind
Any ideas guys? Is there anywhere to get replacement parts for the Devo 10? I'm thinking it could be the main board problem since it beeps on and the buttons does nothing after that.
09 Jul 2014 11:39 #24486 by joeclone
Having a closer look at the pcb, could it be possible that the fall damaged the TKD 8.000 crystal and is preventing the tx to work correctly?
09 Jul 2014 11:43 #24488 by SadSack
Replied by SadSack on topic Devo 10 dun bind
Your really not given out much info.
You can get into DFU so MCU is fine so Xtal is good. Your screen could be broken? No out put at all ? black line so on...
09 Jul 2014 11:48 #24489 by joeclone
There's not much info to give actually, it just powers on with a beep and does nothing. Screen is blank only with the backlight on, no lines, nothing. If the screen is broken, logically I'd still be able to bind with my models right?
09 Jul 2014 11:58 #24491 by SadSack
yeah but when pressing buttons did anything get changed. And you can't see screen you can't say for sure.
If you have emulator install on your pc Try doing button presses on pc and do same on Tx ?
09 Jul 2014 12:03 #24492 by joeclone
Yes thats what I did, simulated with emulator and recreate the step on the tx without the screen. I've left the tx on with throttle up and no timer beeps so I'm pretty sure it does nothing after the power up beep. Pushing any of the buttons also dun get any beeps.
09 Jul 2014 12:06 #24493 by SadSack
connect Tx usb to pc and see if you can get to files on Tx
09 Jul 2014 12:12 #24494 by SadSack
You can get a replacement Screen for 8s but don't know if anyone ever got 10 replacement screen. Rf module easy to get hold of.
You can use other screens and I have done 7e but haven't completed 8080 yet (still lack time/effort and details<<important bit)
09 Jul 2014 12:23 #24496 by joeclone
Yea usb mode works as well, I'm able to get to the model and system files in the tx. Where is it possible to get replacement pcb/ module card?
09 Jul 2014 12:32 #24497 by SadSack
not sure you can and another reason for my interest. The screens parts are very cheap you could get lcd for under $10 but there would be no interface between lcd and mcu and thats what I'm hoping to do. Ask walkera and wait and hope....
09 Jul 2014 12:38 #24498 by joeclone
Thats not very encouraging, hoping for other ideas.... thanks for your help
09 Jul 2014 12:44 #24500 by SadSack
guessing you don't live in UK ?
09 Jul 2014 14:18 #24503 by joeclone
Unfortunately no
09 Jul 2014 14:51 #24504 by aMax
Replied by aMax on topic Devo 10 dun bind
You installed an additional module, did`t you?
May be there is some shortage now. This will prevent the screen coming up too.
...I know this since I added my 7105-DO3 to DEVO7e.... ;-)
09 Jul 2014 16:14 - 09 Jul 2014 16:15 #24505 by joeclone
I've since tried removing both my add on modules and still no go. I even tried removing the stock rf module and still the same.
Last edit: 09 Jul 2014 16:15 by joeclone.
23 Jul 2014 15:35 #24760 by joeclone
An update on this problem I was having, after more tests on the main board it has revealed that the MCU is burnt and I need to replace the STM chip. I need to know how do I proceed after replacing the chip, how do I get the DFU bootloader back and how's the connection and tools/software to do this?
23 Jul 2014 20:24 - 23 Jul 2014 20:26 #24762 by Arakon
Replied by Arakon on topic Devo 10 dun bind
If the STM chip was fried, you wouldn't have been able to flash the firmware or access the USB data. The fact that you can access the virtual drive means that deviation is actually running.
Chances are your PCB or some solder connection has a hairline crack in it. Basically invisible, but some vital line is broken.
Last edit: 23 Jul 2014 20:26 by Arakon.
23 Jul 2014 22:47 - 23 Jul 2014 22:49 #24764 by joeclone
Unfortunately thats what it ended up doing
I've since removed the chip and traced all power pads on the board and no shorts to indicate 5volts or main batt power going in and burning the MCU.
So my question now is how to bring a new replacement chip back to life?
Last edit: 23 Jul 2014 22:49 by joeclone.
29 Jul 2014 14:58 #24888 by joeclone
Anyone can help to explain how I can get the replaced MCU up and running with Deviation?
Time to create page: 0.127 seconds
