Esky F150 Airwolf; Wltoys A979
24 Jul 2014 08:42 - 24 Jul 2014 08:43 #24766 by billmester
Esky F150 Airwolf; Wltoys A979 was created by billmester
I am about to order these:
www.banggood.com/Wltoys-A979-1-Or-18-2_4...-Truck-p-916960.html
www.banggood.com/ESKY-F150-MINI-Scale-La...copter-p-936486.html
I have a Devo10 with a V911 module built in, with Deviation 4.01.
Do I need to install a new module for them and/or do I need to update the Deviation fw? (Are they supported at all?)
(Sorry, I was not following the forum for a while... :( )
bm
Last edit: 24 Jul 2014 08:43 by billmester.
24 Jul 2014 10:14 #24773 by SeByDocKy
Replied by SeByDocKy on topic Esky F150 Airwolf; Wltoys A979
billmester wrote: Hi,
bm
Both need to install the nRF24L01+PA+LNA ..... and good news, both protocols are already supported by the last BN. The car is using the V202 protocol and the Heli, the ESKY150 protocol (not tested yet, at 99% should work)
24 Jul 2014 20:45 #24781 by billmester
Replied by billmester on topic Esky F150 Airwolf; Wltoys A979
Thanks...
you mean this?
www.banggood.com/CC2500-PA-LNA-Romote-Wi...F24L01-p-922595.html
or this?
www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html
If not, could you please link me the items I need?
Can I install it with next to the V911 module or I need to remove it?
Please give me some instructions...
thanks,
bm
24 Jul 2014 21:23 #24782 by SeByDocKy
More this one with the antenna .... (if you don't want to install an external antenna)
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
Yes you cans install a second module while keeping your A7100. Instructions can be find in User manual section I guess
25 Jul 2014 15:14 #24794 by billmester
OK, thanks! :)
"Buy now" button pressed :)
thanks,
bm
30 Jul 2014 01:54 #24898 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Esky F150 Airwolf; Wltoys A979
I love the #3 point on the Airwolf pics; "Lithium battery will be demolished" :blink:
05 Aug 2014 19:11 #25039 by billmester
SeByDocKy,
I receved the module (11 calendar days....WOW!)
Could you please explain me in a few lines how to install it as a second module? What pin goes where? I have a D10.
My v911 module is on "enable-a7105=A13". It was a long time ago when I opened up the Tx last time....
Thanks,
bm
05 Aug 2014 19:33 #25041 by SeByDocKy
billmester wrote: SeByDocKy,
Thanks,
bm
You can find all informations at
bitbucket.org/PhracturedBlue/deviation/wiki/Devo8ModuleInstall
and
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
16 Aug 2014 14:36 #25217 by billmester
OK, done. I've done the install and the TX boots up so far, so maybe I've not ruined too much things :)
My question is, to use the CX-10 (red), is the 4.0.1 good, or I need to install the nightly?
Is the current nightly safe enough? I am flying 450's too... must be safe.
Thanks,
bm
16 Aug 2014 14:44 #25218 by SeByDocKy
billmester wrote: OK, done. I've done the install and the TX boots up so far, so maybe I've not ruined too much things :)
Thanks,
bm
If the Skywalker is available in the 4.0.1 you can keep it ....
16 Aug 2014 19:14 #25220 by billmester
well... YD717 is present, now selectable, but there are no options to choose... that means no, I guess... :unsure:
17 Aug 2014 10:34 #25236 by billmester
Current nightly messed up my screen... had to go back to 4.0.1
What version are you running? If it is stable, could you send it to me? DEVO10...
thanks
bm
17 Aug 2014 10:54 #25237 by SeByDocKy
billmester wrote: Current nightly messed up my screen... had to go back to 4.0.1
thanks
bm
I am using the last NB from august the first
17 Aug 2014 10:56 #25238 by billmester
thanks...
then I'll try again...
Time to create page: 0.624 seconds
