- Cant bind fake HubsanX4 (i.e. X6) to Devo 8
- M-A-X
14 Sep 2014 11:59 - 26 Sep 2014 16:04 #25649
by M-A-X
Cant bind fake HubsanX4 (i.e. X6) to Devo 8 was created by M-A-X
Hey.
I bought a Hubsan x4 from here:
www.ebay.de/itm/Letzte-HUBSAN-H107L-X4-L...&hash=item1c43b0d752
an A7105-Dl3 module from ebay.
www.ebay.de/itm/A7105-500m-wireless-tran...&hash=item19ef00c551
and an Devo8 which came from the US and was upgraded with telemetry module (the cyrf6936 has "WK-21201RF" and "2010.08.03" written on it). Therefor the Pre Owner told me its like an Devo8s. FCC ID: S29DEVO-8
Then i connected the a7105 as said in the ModuleInstallation.pdf from here(actually i used the xl7500 row. I hope thats right for my module) . I also connected pin 8 to ground (3).
Pin 1 and 9 to VDD, Pin 2 to TMS, Pin3 and 8 to the lower middle Pin (Pin 3 and 8 of the CYRF are both ground) on the cyrf. pin 4 to the 2nd pin (upper row) on the cyrf, pin 5 to the 4th pin (upper row) on the cyrf.
In the tx.ini of my deviation 4.0.1 i changed "enable-a7105=A13" and "has_pa-a7105=1" with notepad++ (deleted the ";" in front)
I used the model.ini found here:
deviationtx.com/forum/protocol-developme...art=0&start=20#12575
When i start the Devo8 it says "Hubsan X4 - Binding is in progress... Make sure model is on!......"
Before I turned on the Devo 8, I connected the Lipo to the X4. The LEDs are blinking. Then nothing more happens.
What did i do wrong? Is my X4 a wrong model? Do I need to wire the Module in another way? I also tried the 4.0.1 nightly from 1st August. But this makes no difference. I also pressed "Re-Init" in the Model Config.
Do I need to enter a "Fixed ID" in Model Config?
Last edit: 26 Sep 2014 16:04 by M-A-X.
- mikemacwillie
14 Sep 2014 18:43 #25656
by mikemacwillie
Replied by mikemacwillie on topic Cant bind Hubsan x4 to Devo 8(s) with A7105 module
Sounds like you might have a couple pins mixed up on the CYRF module. The ground pin (3 and 8 on your module connected here) should be the upper middle pin on the CYRF module (The side closest to the shield, pin 3 on the CYRF module). The PDF here
www.deviationtx.com/repository/func-startdown/23/
has pictures of the module pin numbering on page 11. Couple that with the updated chart here:
www.deviationtx.com/forum/6-general-disc...-range-problem#11977
, and you should be successful.
- M-A-X
14 Sep 2014 19:48 - 14 Sep 2014 20:24 #25659
by M-A-X
Replied by M-A-X on topic Cant bind Hubsan x4 to Devo 8(s) with A7105 module
Hey.
Pin Number 3 and number 8 on the CYRF are both GRD. (ground). So its no difference where i connect the a7105... I exactly did what you wrote apart from this. I also crosschecked with a multimeter that 3 and 8 are connected to each other
EDIT: I soldered pin 3 and 8 of the A7105 now to PIN 3 of the CYRF. It didnt change anything.
And this I found in another Forum:
The following is the 8s module pinout:
1: chip select
2: SCK
3: GND
4: MOSI
5: MISO
6: V+
8: GND
10:Reset
Last edit: 14 Sep 2014 20:24 by M-A-X.
- mikemacwillie
14 Sep 2014 22:21 - 14 Sep 2014 22:25 #25668
by mikemacwillie
Ah, of course. If they're both ground, then that's not the issue. From the picture, you wiring looks good, as long as TXEN is connected to VCC (can't see it behind the module). If it is, you either have a dead module, or a configuration issue. Are you using one of the nightly builds, or the 4.0.1 build?
Edit: I checked out the ebay listing.. That looks to be a knockoff X4. If that's the case, it's entirely possible it doesn't use the same radio protocol. The box in the picture says is marked differently than the Hubsan. The motors are mounted slightly differently too.
www.hubsan.com/manageCenter/FCKeditor/Fi...D%A9%E7%9B%92.21.jpg
Last edit: 14 Sep 2014 22:25 by mikemacwillie.
- M-A-X
15 Sep 2014 06:32 - 15 Sep 2014 11:09 #25678
by M-A-X
Hey.
Damn... Yeah. The Box I got says x6.
But as there was 'x4 h107` in the auction Text I thought that its a wrong labeled Box...
Any idea how to Check this for sure?
Or has anybody the same Hubsan and knows what to do?
I opened a case at ebay because of the wrong title... I dont need a Quattrocopter that I cannot use with my Devo8
Last edit: 15 Sep 2014 11:09 by M-A-X.
- mikemacwillie
16 Sep 2014 02:45 #25688
by mikemacwillie
It might use one of the other compatible protocols.. You could open up the transmitter or the quad, and see what radio chip is in it.. Might help narrow it down.
- btoschi
16 Sep 2014 20:13 - 16 Sep 2014 20:14 #25696
by btoschi
Replied by btoschi on topic Cant bind Hubsan x4 to Devo 8(s) with A7105 module
This quadcopter is a FY310, I'm not too sure about the protocol.
You should definitely try every single nRF based protocol available in deviation (don't forget to test all different protocol variants of YD-717), as there is a major chance they use one of them.
You can see a picture of receiver PCB on this site:
www.walkera-parts.com/x6-4ch-mini-video-...lack-red-mode-2.html
The PCB seems to be labeled "ABE CM2" (or something like that), I've seen the name "ABE" on some UDI boards before.
In case it's using an older UDI protocol, it will not work with deviation yet (still working on this) and there is some chance it will only work when I get SPI traces of it, since UDI protocols used to change with each model (new models from 2014 are compatible with each other, btw).
In case you cannot get your money back and nothing works, please provide pictures of TX and RX boards, so we can remotely identify RF chip and possibly more. SPI traces of TX would be great but you'd need a logic analyzer for that.
Last edit: 16 Sep 2014 20:14 by btoschi.
- M-A-X
18 Sep 2014 14:18 - 18 Sep 2014 14:37 #25716
by M-A-X
Hey.
On the "only" Chip that i can see in the RX (RX = Receiver? = Model?) is written:
STMASOO
SK6T6C
GH209 F6
CHN 412
On the Board is ABE-QW3A
On the MainBoard of the Tx (Transceiver? = Radio Controller?):
JLDZ-4Axis-4tx
On the Board of the Tx (the one where the antenna goes out):
ABE 2.4GCOB-1A
There are 3 other Chips on the Mainboard. 1 with 24 Pins without label.
1 with more Pins^^ with:
HOLTEK
HT1621B
A128G0303#7
and 1 with 8 pins:
ATMEL 41S
2.4G02BN
SU27 D
and a small one with 4 pins (3 on one side 1 on the other)
AMS1117
3.3 1402
I dont know if thats all 100% correct as its very small written^^ also the O can be 0 :=)
EDIT: As my Camera is loading atm i cant make any pictures. But I will.
To test "all" protocols: How do I do that
? I used the X4.ini from above and just changed the Protocol in the Model Screen. Restartet the X6 between all switches.. and Reinit or Bind in Menu. Nothing seemed to work (LEDs on X6 kept blinking - no bind).
How do i "test all different protocol variants of YD-717"? When i choose YD-717 there is a "*" in front and I Cant click it. (its white - not grey)
EDIT2: I dont have a logic analyzer.. nor do i know what this is or how to use it
STMASOO
SK6T6C
GH209 F6
CHN 412
JLDZ-4Axis-4tx
ABE 2.4GCOB-1A
HOLTEK
HT1621B
A128G0303#7
and 1 with 8 pins:
ATMEL 41S
2.4G02BN
SU27 D
AMS1117
3.3 1402
Last edit: 18 Sep 2014 14:37 by M-A-X.
- mikemacwillie
18 Sep 2014 14:41 #25717
by mikemacwillie
To test all of the UDI/nRF protocols, you'd need the NRF24L01 module.
- M-A-X
18 Sep 2014 15:04 - 18 Sep 2014 15:30 #25718
by M-A-X
Hmm.. How do i connect this? and how do i activate it in tx.ini? In the Manual there ist only
CC2500-PA
XL2500-D03
skyartec
XL7105-D03
V911
Or is it just another name for one of those
? AFAIK I can connect 2 Modules to the Devo8. 1 TMS and 1TCK.
I would do that if I know how
Is that the correct one?
www.ebay.de/itm/2-4G-NRF24L01-PA-LNA-Wir...&hash=item4ad9491bd6
or should i get one like this with an external Antenna? (Would prefer the first one if the range is ok as i dont have to mod the case of my devo8^^)
www.ebay.de/itm/Neu-2-4G-1100m-NRF24L01-...&hash=item2a42ea0e95
EDIT: I found a manual:
GND -> GND (Pin 3/8 )
VDD -> VDD (on Debug Port)
CE -> VDD (on Debug Port)
CS(N) -> TMS/TCK (one empty) (on debug port)
SCK -> SCK (on CYRF PIN 2)
MOSI -> MOSI (on CYRF PIN 4)
MISO -> MISO (on CYRF PIN 5)
IRQ -> free
is that correct? Is the built in Antenna good enough or should i get a Modul with external antenna?
CC2500-PA
XL2500-D03
skyartec
XL7105-D03
V911
IRQ -> free
Last edit: 18 Sep 2014 15:30 by M-A-X.
- mikemacwillie
18 Sep 2014 15:33 #25719
by mikemacwillie
Yep, that looks correct. I haven't tried the ceramic antenna model, and it's probably not the best choice. I have this one in one of my transmitters
www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html
, and it has been working well with a sleeve dipole (Something like this:
www.banggood.com/Wholesale-FrSky-Receive...na-25cm-p-68700.html
) up in the antenna tube.
- M-A-X
18 Sep 2014 16:10 - 19 Sep 2014 17:00 #25722
by M-A-X
Last edit: 19 Sep 2014 17:00 by M-A-X.
- mikemacwillie
20 Sep 2014 00:18 #25741
by mikemacwillie
Unfortunately the RF IC if the one that you have as unlabeled. On the quad it's probably on the other side of the board, the IC in the pictures is the microcontroller. I don't have access to one of these knockoff X4s, so unfortunately I can't really give you any hints other than what btoschi has provided above.
20 Sep 2014 01:29 #25742
Replied by hexfet on topic Cant bind Hubsan x4 to Devo 8(s) with A7105 module
That's the same RF module used in the YD717 tx. No guarantee the protocol will work, unfortunately. You will need to add the nRF module to your tx to try.
- M-A-X
21 Sep 2014 11:37 - 22 Sep 2014 16:50 #25750
by M-A-X
Ok. Thanks.
I will have a look at the Copter if I can get a picture of the other side of the board.
I also ordered a nRF module in china and will add it to the Devo.
I will write again as soon as i get any results
EDIT:
Well.. There is the back of the board. I cant get a sharp image
The "only" chip is labeled:
INVENSENSE
MPU 6050C
D3B68S-B1
EL 1401 E
EDIT:
INVENSENSE
MPU 6050C
D3B68S-B1
EL 1401 E
Last edit: 22 Sep 2014 16:50 by M-A-X.
- Daryoon
24 Sep 2014 23:07 #25798
by Daryoon
Replied by Daryoon on topic Cant bind Hubsan x4 to Devo 8(s) with A7105 module
At least the good news is...once you get the NRF24L01 module installed...you'll have access to many, many more quads, helis, etc.
- M-A-X
26 Sep 2014 16:01 - 26 Sep 2014 16:03 #25814
by M-A-X
Well..
I hope the module will work ^^
I definitly didnt get a X4...
www.hubsan.com/products/HELICOPTER/H107L.htm
Maybe some Admin want to change the Topic? So it matchs my "X6"
EDIT: Nevermind^^ did it myself
Last edit: 26 Sep 2014 16:03 by M-A-X.
- mikemacwillie
26 Sep 2014 20:29 #25818
by mikemacwillie
There's a good possibility you'll find a protocol that works. Unfortunately trying it is probably your best option at this point. The RF IC die is under that blob of potting epoxy.
- M-A-X
28 Sep 2014 08:39 #25844
by M-A-X
I scrathed the epoxy from the IC. Its labeld with only 307 or 3O7 or maybe (if i scratched too much) 807 8O7^^
- kfinisterre
02 Oct 2014 18:17 - 02 Oct 2014 18:18 #25926
by kfinisterre
Replied by kfinisterre on topic Cant bind Hubsan x4 to Devo 8(s) with A7105 module
I can see from your 3.JPG photo that this uses BK2421 just like the craft I just tore apart -
www.amazon.com/Attop-Yd-928-2-4ghz-Quadc...copter/dp/B00I0K5SMW
When I did the teardown I found the YD-928 had a BK2421 as per - dzlsevilgeniuslair.blogspot.com/2013/11/...dcopter-hacking.html
This may be useful to someone?
dl.dropboxusercontent.com/u/2248531/blog/HCD/HCD_init.txt
Last edit: 02 Oct 2014 18:18 by kfinisterre.
Time to create page: 1.677 seconds
