DEVO 8S problem power on. SOLVED! ;)
09 Oct 2014 06:16 - 11 Oct 2014 08:23 #26017 by galaxy76
DEVO 8S problem power on. SOLVED! ;) was created by galaxy76
hello. suddenly my DEVO 8S does not turn on anymore. without any reason. I never updated, I never fall to the ground. now no longer turn on. The display is turned off, only the red LED will light for a moment. from what could be the problem?
video show the problem
Last edit: 11 Oct 2014 08:23 by galaxy76.
09 Oct 2014 14:28 - 09 Oct 2014 14:38 #26018 by aMax
Replied by aMax on topic DEVO 8S problem power on.
Check the switch, it may be worn.
Open the TX and check connections with a multimeter.
EDIT: Try to stop moving the switch when the led lights up, not complete to end
position. If the TX is starting ......
Last edit: 09 Oct 2014 14:38 by aMax.
09 Oct 2014 22:16 #26021 by mikemacwillie
Replied by mikemacwillie on topic DEVO 8S problem power on.
At first glance, it looks like a power supply problem to me. Double check your battery first, and make sure it's not tanking under load.
10 Oct 2014 20:11 - 10 Oct 2014 20:44 #26032 by galaxy76
Replied by galaxy76 on topic DEVO 8S problem power on.
finally, after 2 evenings are managed to fix it. of course was not a simple switch defective or low battery :whistle: . I had to replace the voltage regulator that power of the processor and one mosfet . not finding what exact I have put one a little bigger. so this time you do not break so easily. ;)
Last edit: 10 Oct 2014 20:44 by galaxy76.
10 Oct 2014 20:18 #26033 by galaxy76
and a video that shows that the radio works... :P
Time to create page: 0.030 seconds
