- Hooking up Logic Analyzer ....Help please
- magic_marty
06 Dec 2014 23:17 #26820
by magic_marty
Replied by magic_marty on topic Hooking up Logic Analyzer ....Help please
Gonna try rolling back to older firmware to see if it works..if not i will hook up the analyzer again and see if i can figure out anything but i have no idea how ti use that thing..so not sure what to look for or how to go about getting results that show something wrong.
- aMax
06 Dec 2014 23:32 - 06 Dec 2014 23:47 #26822
by aMax
Replied by aMax on topic Hooking up Logic Analyzer ....Help please
Then you will have to learn it....
I think you do too much steps at once. First check it with that version.
If you have no success you may change back.
Hook up CSN and set the samplefrequence to 1 or 2 Mhz to see if a signal is present.Sample a bigger file.
Edit:
downloads.saleae.com/Logic+Guide.pdf
or
Edit:
or
Last edit: 06 Dec 2014 23:47 by aMax. Reason: add links
- magic_marty
06 Dec 2014 23:40 #26823
by magic_marty
OMG!!! it works when using Deviation 4.0.1 so its something in the nightly builds that is causing not to work...Bad thing is if i don't run the nightly i can't fly my models with ether tx without having to re-bind them each time...with the nightly i just pick up ether tx and turn it on and fly..
- aMax
06 Dec 2014 23:49 #26824
by aMax
I think you messed it up with your file copy action from Devo 8 to 12....
- magic_marty
07 Dec 2014 00:31 #26826
by magic_marty
So i will try reinstalling the nightly and just changing the tx ID to match the 8 and see if it works without copying any files from the 8 ...the only files i will copy is the model file i have saved for the 12
but i honestly think it wont work cause i tried it before i copied the hardware file from the 8 and it didn't work but will see...fingers crossed..
- magic_marty
07 Dec 2014 01:29 #26829
by magic_marty
Something in the nightly builds cause soon as i put it back i get the same issue...missing module didn't copy the hardware file from the 8 just enabled the modules and it powers up but i have the *in front of the protocals ..it works on the stock deviation 4.0.1 firmware...not sure why it wont work on the 12 but it has to be in the nightly builds firmware...
13 Dec 2014 23:37 #26938
Replied by mwm on topic Hooking up Logic Analyzer ....Help please
Any chance there's a good tutorial/instruction/examples for logic analyzers on the net somewhere? I've got mine, and two or three projects that it would be useful for, but also no idea how to use it.
- magic_marty
14 Dec 2014 00:00 #26940
by magic_marty
hooking it up is not to bad its the settings and what to look for when its hooked up..just shows a bunch of squiggly lines ect...
14 Dec 2014 00:30 #26942
I believe you. That's why I'd really like a tutorial, showing how to hook it up to some microcontroller, adjust the settings to make the signals easily visible, and then how to interpret them. I'm hoping someone knows of such, because my Google fu wasn't strong enough to find one.
- magic_marty
14 Dec 2014 00:36 #26944
by magic_marty
i am going to hook mine up again to my 12 and see if i can figure out why the NRF module is not working but its going to be a steep curve to figure it out...first time i hooked it uo i didn't have the settings correct and couldn't figure anything out ...least this time i have the test clips to hook it up with..
- aMax
14 Dec 2014 01:32 - 14 Dec 2014 01:41 #26948
by aMax
... can´t be that hard..
Choose 10M Sample, 2 or 4 Mhz, on the right side choose analyzer "SPI".
Let it be renamed, hook the lines(clips) according to the signal names and give it a go,.....save the dump. If you are wrong with the naming, it could be altered afterwards.
The main signal you should be looking for, is the "CSN". The rest does not care at the moment.
The best way would be to start on the Devo8 and do a protocol change or model change. Then you have an example how it should look like.
Edit: By clicking into the screen with left/right mouse button you change the
timebase for better view.
magic_marty wrote: i am going to hook mine up again to my 12 and see if i can figure out why the NRF module is not working but its going to be a steep curve to figure it out...first time i hooked it uo i didn't have the settings correct and couldn't figure anything out ...least this time i have the test clips to hook it up with..
Last edit: 14 Dec 2014 01:41 by aMax.
- magic_marty
14 Dec 2014 01:50 #26949
by magic_marty
how is it saved? it just ask to save as screen shot..
- aMax
14 Dec 2014 01:58 - 14 Dec 2014 02:01 #26951
by aMax
Save session or export data.To save the session the best way as you can always reload it to compare.
Last edit: 14 Dec 2014 02:01 by aMax.
- magic_marty
14 Dec 2014 02:25 #26952
by magic_marty
ok got it hooked to the 8 and going to try this again
- magic_marty
14 Dec 2014 02:50 #26953
by magic_marty
devo8 export files nrf and devo protocol
- magic_marty
14 Dec 2014 03:16 #26954
by magic_marty
devo12 export files ...
- magic_marty
14 Dec 2014 03:22 #26955
by magic_marty
devo12 tx with the devo protocol and 12ch rx
- magic_marty
14 Dec 2014 03:34 #26956
by magic_marty
i have no idea what to look for with these exports?? thats why i posted them here..maybe somebody can see something wrong..
- aMax
14 Dec 2014 04:18 - 14 Dec 2014 04:41 #26957
by aMax
Please stop flooding the topic with useless binary files.
A session file would be nice or at least exported as CSV file, which is a text file.
Example:
Power on of a WLToy A7105 tx. The first signal(obove) is that what we seach on your installation.
Example:
Last edit: 14 Dec 2014 04:41 by aMax.
- magic_marty
14 Dec 2014 04:42 #26958
by magic_marty
nobody never said what type of file to save them as...i only have .bin on the 12 but have a cvs on the 8
Time to create page: 0.896 seconds
