Help with DEVO 7e DFU drivers
- tasos2008
19 Jan 2015 20:04 #27859
by tasos2008
Help with DEVO 7e DFU drivers was created by tasos2008
Hi, i have tried in two computers a laptop with fresh install win 7 32 bit and another with win 7 64 bit,but i cannot install dfu drivers to flash deviation.I have made all the solutions i read on the net but nothing.Please help
- aMax
19 Jan 2015 20:45 #27861
by aMax
Replied by aMax on topic Help with DEVO 7e DFU drivers
- tasos2008
20 Jan 2015 12:48 #27882
by tasos2008
Replied by tasos2008 on topic Help with DEVO 7e DFU drivers
thanks, i will try to other computer to see what happens and i will tell you
- tasos2008
24 Jan 2015 21:20 #27979
by tasos2008
hello, i have read and done all the link says and even tried to another 2 pcs.The problem still the same in devices menu under universal serial bus devices is still "STM32 Virtual COM Port" please help
- Arakon
24 Jan 2015 22:36 #27980
by Arakon
Replied by Arakon on topic Help with DEVO 7e DFU drivers
Did you actually hold the EXT button while turning on the transmitter?
- aMax
24 Jan 2015 23:35 #27983
by aMax
for special cases.....
- H8flyer
22 Jan 2016 01:37 #42048
by H8flyer
Replied by H8flyer on topic Help with DEVO 7e DFU drivers
I had similar problems with device drivers in Windows 8.1. I opened the DFU upgrade tool, plugged in my Devo 7E, turned it on while pressing ext, and nothing.
I checked the device driver in windows device manager, and there was a yellow asterisk on the device. I tried updating the device driver and pointed windows to the deviation folder to find the driver, but windows couldn't find the driver.
I turned my Devo off, and closed the upgrade tool. I reopened the upgrade tool, turned on the Devo while pressing ext, and it showed up in the upgrade tool. I hope this works for everyone else with this problem.
- slo_rider
26 Jan 2016 19:17 #42253
by slo_rider
Replied by slo_rider on topic Help with DEVO 7e DFU drivers
I was having a similar problem, Dfuse application installed fine, but my McAfee AV was blocking some of the changes, so it was not detecting my Devo when plugged in. Same result on two computers. Disabled McAfee and reinstalled Dfuse and it worked fine after that.
Time to create page: 0.093 seconds
- Help with DEVO 7e DFU drivers
