Help with V922
20 Jan 2015 13:45 #27885 by retiredfist
Help with V922 was created by retiredfist
I have a V922 board on an MCPX Frame, Main & Tail motor, & using MCPX servos (signal wires reversed)with deviation and NFR24L01 module.
It binds but the servo seems to behave weird
Can anyone help advise with the following please
From the frame of the helicopter Does the:
Left Servo = Pitch?
Right Servo = Elevate?
Back Servo = Alieron?
Reverse ???
Swash Type = 3Servo120
ALE Mix = 60
AIL Mix = 60
PIT Mix = 60
Mixer GUI = Standard
Protocol Hisky
Channels = 6
Been trying to get this thing right for just under a week but now really baffled...
20 Jan 2015 23:01 #27909 by hexfet
Replied by hexfet on topic Help with V922
On my v922 the controller board is mounted with connectors facing aft. The port connector goes to the port servo. The connector adjacent to that goes to the aft servo. Third connector from the port side goes to the starboard servo. Top horizontally-mounted connector is tail motor; main motor connector is underneath it.
My model file is attached. I think I downloaded one from the model configs section but changed some settings - details are foggy...
21 Jan 2015 09:10 #27914 by retiredfist
Replied by retiredfist on topic Help with V922
I friend stopped using the mxpx V1 so gave it over to me as he has moved onto a Super CP.
The MCPX V1 board is faulty anyway so I purchased the V922 board.
The V922 board has ports labelled
Pitch
Aileron
Elevate
Now just slightly confused how my MCPX Servos all connect to it.
If you have a photo of which servos connect where, that would be very helpful :cheer:
Once I see how you've connected your servo, I'll upload your config file to my TX and try it...
21 Jan 2015 23:30 #27926 by hexfet
Hope this helps
21 Jan 2015 23:39 #27927 by hexfet
Hope this helps!
File Attachment:
Time to create page: 0.105 seconds
