PPM IM causes Crash on my Devo12s
- Wene001
05 Mar 2015 20:03 - 05 Mar 2015 20:08 #29365
by Wene001
PPM IM causes Crash on my Devo12s was created by Wene001
Hi
Played around with some Trainer configs
Please anybody can confirm this bug?
Fresh installation v4.0.1-33ce342 on my Devo 12s
(same problem with earlier versions)
Empty Model...Model Setup....Change PPM In to "Extend"...In extend settings change Num Channels to 4...goto Mixer Page...Klick at channel 1 on Simple and Change SRC to "PPM2"... ok.....CRASH without saving config.
Assigning PPM1 to Channel 1 makes no Problem e.g.
Assigning PPM2 to channel 2 makes no problem ...
Other way round CRASH
I've created an entry in the new bugtracker...
edit: Same one my Devo6s with v4.0.1-92e1705
Last edit: 05 Mar 2015 20:08 by Wene001.
05 Mar 2015 21:07 #29374
Replied by hexfet on topic PPM IM causes Crash on my Devo12s
Reproduced on Devo 10. I updated the issue. Thanks for reporting it!
- Wene001
07 Mar 2015 08:25 #29423
by Wene001
Replied by Wene001 on topic PPM IM causes Crash on my Devo12s
Do you have a testversion to try on DEVO12 to see its workin properly?
Thanx for the quick fix
07 Mar 2015 13:01 #29429
The day after an issue is fixed you can follow the Downloads link on the left to Nightly Builds to find the latest builds. The March 7 build is
here
You're welcome. Issues for reproducible resets don't last long.
I've also tested feeding ppm into my 10 and it showed up fine in the channel monitor.
- Wene001
08 Mar 2015 17:00 - 08 Mar 2015 17:01 #29459
by Wene001
Works like a charm
One minor bug i`ve seen is:
If you use the PPMIn Mode "Channel" the "PPM Movement" is only seen in channel monitor , not on the channel bars on the homescreen.
PPM Sigals used in the Modes "Extend" and "Sticks" are showed up as they should in Channel Monitor and on the homescreens channel bars
Last edit: 08 Mar 2015 17:01 by Wene001.
- Wene001
10 Mar 2015 21:16 #29533
by Wene001
@Hexfet
Do you have this behavier too?
11 Mar 2015 04:05 #29557
Yes, same on my 10. The code is displaying the mixer output instead of the channel values used by the protocols - which are the same in all cases except when PPM In is set to Channel. Should have a build to try in a day or two.
12 Mar 2015 23:55 #29617
Please try the attached build. It has the change described
here
Time to create page: 0.127 seconds
- PPM IM causes Crash on my Devo12s
