deviation-devo F12E
25 May 2015 08:03 - 25 May 2015 08:21 #32953 by vlad_vy
Replied by vlad_vy on topic deviation-devo F12E
On the image of Video connector marked 5 channels - Ch1, Ch2, Ch3, Ch4 and Ch5. Or it's something else, not video channels wires? Devo F12E manual has reference to 32 channels.
Last edit: 25 May 2015 08:21 by vlad_vy.
25 May 2015 14:46 - 25 May 2015 14:47 #32960 by PhracturedBlue
Replied by PhracturedBlue on topic deviation-devo F12E
Thanks Vlad.
That CH5 is connected on the other end to a pin called A6.0 which I had assumed was connected to the Audio port. In reality the 6.5M pin is connected to the Audio jack. The A6.0 pin seems to be connected to PD.8 through a 220-ohm resistor though it is tricky to follow due to being obscured by switches and whatnot.
Last edit: 25 May 2015 14:47 by PhracturedBlue.
30 May 2015 16:45 #33248 by PhracturedBlue
Okay, I have finally finished getting the F12E supported in the Deviation Uploader, and the Deviation can now be run on the F12E by anyone who wants to try.
You need to use my custom uploader to install everything.
1st downalod the latest nightly build for the F12E from the donwload section
2nd follow the instructions here to install it:
www.deviationtx.com/forum/7-development/...bcode?start=40#33247
30 May 2015 22:04 #33269 by ghostkcleung
Replied by ghostkcleung on topic deviation-devo F12E
I've been flash to deviation with my F12E.
Thank you very much.
Be attention when fall back to the devention original firmware.
There is throttle stick warning. You need to pull the right side stick to turn it on.
31 May 2015 14:32 #33282 by mrbeefy
Replied by mrbeefy on topic F12e now fully supported?
Is it?
31 May 2015 15:23 #33284 by PhracturedBlue
Replied by PhracturedBlue on topic F12e now fully supported?
Please don't start new threads when there is a perfectly good active thread already available.
And yes, the F12E is supported now (though still experimental). I haven't implemented the Standard GUI yet, and lots of testing is needed, but it is working. Read above for instructions as installation is NOT like other Devo radios.
12 Jun 2015 00:04 #33888 by dc59
Replied by dc59 on topic F12e now fully supported?
PhracturedBlue wrote: Please don't start new threads when there is a perfectly good active thread already available.
Hi PB,
Is that mean, F12E has full function as DEVO8 now? can I install NRF24L01 module in F12E?
12 Jun 2015 00:36 #33892 by PhracturedBlue
In theory yes. The F12E uses the standard module, so installation is just like the devo8 (there are 2 RF modules in a F12E, so make sure you use the 2.4GHz one). The standard mixer is not implemented yet, but everything else should be there.
12 Jun 2015 08:39 - 12 Jun 2015 08:40 #33909 by dc59
Replied by dc59 on topic deviation-devo F12E
Thanks PB.
I always use advanced mixer,there's no problem for me.
I'll try to install nrf24l01 module in F12E for my toy quads(with FPV mods.) and will report result.
Last edit: 12 Jun 2015 08:40 by dc59.
14 Jun 2015 00:18 #34034 by dc59
NRF24L01 was installed, works good so far! :lol:
Hi PB,
Could you fix battery voltage bug? I use NiMHx8 , voltage should around 10v, but it shows around 6v,
and max voltage alarm ~6v, it should higher!
14 Jun 2015 04:02 #34043 by PhracturedBlue
Please file a ticket on it. I need to run the calibration routines to determine the proper scalars.
14 Jun 2015 08:19 - 14 Jun 2015 08:21 #34050 by Guiliman
Replied by Guiliman on topic deviation-devo F12E
This is really cool.
I want to add 2 modules because of the different receivers I have.
What I haven't understood until now, does it need a physical switch to switch between the modules or is there a Software function for it?
Guiliman
Last edit: 14 Jun 2015 08:21 by Guiliman. Reason: Typo error
14 Jun 2015 12:53 #34056 by PhracturedBlue
It is all done through the transmitter software (once you've made the hardware mods). However, I really recommend trying Deviation before you commit to modifying your Tx. It is unlike the stock firmware, and you should be sure it is what you want.
14 Jun 2015 23:55 - 14 Jun 2015 23:55 #34083 by dc59
PhracturedBlue wrote: Please file a ticket on it. I need to run the calibration routines to determine the proper scalars.
Should I pull request HERE ?
Last edit: 14 Jun 2015 23:55 by dc59.
15 Jun 2015 00:42 #34085 by PhracturedBlue
Not unless you can fix the bug yourself. Otherwise, click the 'Bug Tracker' on the left of your screen and enter the issue
15 Jun 2015 01:35 #34087 by dc59
Hi PB,
Need your help.
I can't find 'Bug Tracker' on screen , it's my first time to use bitbucket . :oops:
15 Jun 2015 01:40 #34088 by PhracturedBlue
the bug tracker is on the forums, not bitbicket. it is right there on your screen right now as you read this.
15 Jun 2015 02:06 #34089 by PhracturedBlue
FYI, while you should probably learn how to file a bug, I have resolved the issue. Tomorrow's build will have the proper battery callibration
15 Jun 2015 02:35 #34092 by dc59
PhracturedBlue wrote: FYI, while you should probably learn how to file a bug, I have resolved the issue. Tomorrow's build will have the proper battery callibration
Thanks PB!! :cheer:
Now I know how to file bug :lol:
18 Jun 2015 09:40 - 18 Jun 2015 09:41 #34269 by dc59
Hi PB,
Thanks for fixing battery issue.
I have some questions,need help.
1, F12E video/display contrast seems not good enough,can it be adjust by FW?
2, Everytime I upgraded new FW(new build) , all .ini file and model file always be reset/replaced ,
I'm sure that I did not select 'replace tx.ini / model file /..... ' item while upgrade new build.
did I do anything wrong?
Last edit: 18 Jun 2015 09:41 by dc59.
Time to create page: 0.483 seconds
