Devo 6s and unmixing Blade MSR
- 26y4u
12 Mar 2015 22:01 #29615
by 26y4u
Devo 6s and unmixing Blade MSR was created by 26y4u
hi all,
today i got my devo 6s.
it fits really good in my hand and the deviation fw is fantastic.
after playing around with it a bit i got few questions.
first whats the rubber socket on the back side under the antenna?
cant the up/dn and r/l buttons act like 2 positions switches?
can deviation integrate a text editor so i can manipulated the ini directly.
is the 6s exactly the same as 8s with the exception of the two extra switches?
so theoretically i can use the 8s fw?
furthermore is it possible to mod the screen to non-glare?
and my last question is how i unmixing the blade msr.
the rudder mixing in the elevator servo.
i dont wanna the elevator servo to move when i move the rudder.
i tried with complex and two mixer.
the first one src RUD and the second one src ELE but failed.
best regards
best regards
- Thomas.Heiss
13 Mar 2015 14:14 #29645
by Thomas.Heiss
Is it USB port?
It's the case for Devo 10.
It does not. You connect the TX to your computer in USB mode.
See manual for ENT or EXT buttons + power on.
Devo 6 Firmware: www.deviationtx.com/downloads-new/catego...viation-devo6-v4-0-1
Replied by Thomas.Heiss on topic Devo 6s and unmixing Blade MSR
26y4u wrote: first whats the rubber socket on the back side under the antenna?
Is it USB port?
26y4u wrote: can deviation integrate a text editor so i can manipulated the ini directly.
26y4u wrote: so theoretically i can use the 8s fw?
- 26y4u
14 Mar 2015 16:16 #29701
by 26y4u
Replied by 26y4u on topic Devo 6s and unmixing Blade MSR
u can c it on the photo.
theres a rubber socket.
i know u can edit the files on pc in usb mode.
would be great to be able to edit it on the touchscreen although.
i already have the firmware installed.
i was just asking if the hardware is identical.
if it is there should be no problem if u using the devo8 fw.
best regards
best regards
15 Mar 2015 18:00 #29747
Replied by mwm on topic Devo 6s and unmixing Blade MSR
The port on the back doesn't appear to have any use. It isn't mentioned in the manual.
USB is on the right-hand side near the bottom, charge and trainer ports are on the back near the bottom, one near each side. Those three are the only external ports on the Devo Tx's.
- Cereal_Killer
15 Mar 2015 19:01 #29749
by Cereal_Killer
Replied by Cereal_Killer on topic Devo 6s and unmixing Blade MSR
My brand new 7E has that same port on the back, there isn't a socket or even breakouts under it for an add-on module or anything... Probably a planned factory add-on / upgrade than never came to be, it's useless.
I thought about using mine for an easy add-on antenna install but I don't do anything the easy way lol.
Time to create page: 0.056 seconds
- Devo 6s and unmixing Blade MSR
