OrangeRx R615x and Devo7e problem
31 Mar 2015 18:15 #30563 by mfarias56
OrangeRx R615x and Devo7e problem was created by mfarias56
Having an issue with holding a bind between the 7e and the R615x in DSM2. The 7e is running a nightly build. I had done a hover test on a newly built quad several days ago with out issue. I have since added a A7105 module to the 7e so I can use it with my hubsan. Now when I try and bind to the R615x the signal comes and goes. The channels get stuck in position for several seconds then become responsive again. It's happening in DSMx also. No issue with Hubsan is not having any issues.
Any suggestions on what the problem is or how to trouble shoot it???
31 Mar 2015 19:36 - 31 Mar 2015 20:15 #30569 by aMax
Replied by aMax on topic OrangeRx R615x and Devo7e problem
What do you expect now?
No version numbers for the two nightlys, no info about your wiring on the A7105,
and...
Did you inspect your work carefully?
Edit: Any different model for testing the CYRrf modul with another protocol?
Edit_2: Ok, found the infos...
www.deviationtx.com/forum/6-general-disc...lp-devo-7e-and-a7105
But here the A7105 was not binding. What did you change?
Last edit: 31 Mar 2015 20:15 by aMax.
31 Mar 2015 22:05 #30582 by mfarias56
Replied by mfarias56 on topic OrangeRx R615x and Devo7e problem
That earlier post regarding the A7105 was a problem with the module its self. I replaced it with a different A7105 and the Hubsan binds fine now.
The nightly I am running is v4.0.1-e1a3b14.
No other models available to test. Just the R615x and 2 Hubsans.
01 Apr 2015 02:16 #30598 by mikemacwillie
Replied by mikemacwillie on topic OrangeRx R615x and Devo7e problem
Do you have telemetry turned on by any chance?
01 Apr 2015 02:18 #30599 by mfarias56
I did yes
02 Apr 2015 16:57 #30697 by Cereal_Killer
Replied by Cereal_Killer on topic OrangeRx R615x and Devo7e problem
Can you show some pic's of the install? I just got done sorting threw an issue of sporadic signal to a 6Ch DSM2 Lemon Rx from my 7E that was caused by the 3 antenna lines being tangled. I have a NRF and an A7105 module installed, both with real [external] antennas (plus an add-on external antenna for the OE module) and my DSM2 range, while it wasn't bad in a straight LOS, was blocked by nearly anything (a sheet of cardboard / my arm). I re-routed the antenna lines and kept them apart and the signal cleaned up.
Time to create page: 0.092 seconds
