Small problem with Deviation
- saidem
06 May 2015 16:54 - 20 May 2015 18:23 #32181
by saidem
Small problem with Deviation was created by saidem
I just spent my Devo 8S in Deviation and when I turn it on, it makes a screen scanning, I wanted to know if you have the same thing and is what's it to malfunction.
Thank you for your answers.
Last edit: 20 May 2015 18:23 by saidem. Reason: Mistake
- saidem
20 May 2015 18:28 #32803
by saidem
Replied by saidem on topic Small problem with Deviation
Does anyone had this problem?
20 May 2015 19:32 #32806
Replied by PhracturedBlue on topic Small problem with Deviation
I'm not sure what you mean by a 'screen scanning' can you describe further?
- saidem
21 May 2015 16:56 - 26 May 2015 17:14 #32832
by saidem
Thanks PB.
When I switches the TX on the screen appears as a scanning at 30 °, the bottom of which is inclined banked to the right which divides the screen into two or 3 then a first mask "Safety" appears with a frame thin vertical and then the mask "Safety" is displayed properly.
I have no problem to extinction.
I filmed with my mobile, but it should be too fast and you see nothing.
Last edit: 26 May 2015 17:14 by saidem.
- saidem
26 May 2015 17:14 #33019
by saidem
What do you think?
26 May 2015 19:44 #33027
I have never seen anything like that. I think I need a picture/video of it. happening.
does it go away once you set the safety properly?
Time to create page: 0.935 seconds
- Small problem with Deviation
