How to update?
20 May 2015 23:36 #32809 by ursus69
How to update? was created by ursus69
Sorry for the question....i'm deviation noob...
I'm running Deviation 4.0.1, and I do the 3x2 switch mod...
How I have to update to the nightly built? First the Dfuse tool? But after, need to enter with ENT+on + format?
Need to do all the steps like the video?
Thanks!!
21 May 2015 04:18 - 21 May 2015 04:19 #32812 by Arakon
Replied by Arakon on topic How to update?
You update the same way you installed the firmware originally. First DFuse and then copy the file system over. No need to format, though.
Back up all your model files and custom graphics, if any, they will be overwritten.
Or just don't copy the model folder.
Last edit: 21 May 2015 04:19 by Arakon.
21 May 2015 08:56 #32822 by ursus69
Replied by ursus69 on topic How to update?
Thanks Arakon!
Another question... What differences are between Deviation 4.0.1 and Nightly builds?
21 May 2015 14:44 #32827 by victzh
Replied by victzh on topic How to update?
A lot has changed, I don't even know where to start. Many subsystems were reworked, the most important and user visible is separation of module information from tx.ini to hardware.ini. Protocols were added also.
21 May 2015 15:17 #32828 by ursus69
Ok, thanks victzh!
I need to install it and try!
21 May 2015 20:23 #32840 by ursus69
I do the update, and now works the 3x2 switch mod..
But, I have the range mod, and now with the nightly, I can't modify the Tx power... it's normal?
It's in "Default", and I can't change it...
Any solution?
21 May 2015 22:45 #32843 by aMax
Replied by aMax on topic How to update?
Have a look at the hardware.ini.... :whistle:
22 May 2015 00:00 #32847 by ursus69
I power off, and power on...and now appears...
In the hardware.ini I had the has_pa-cyrf6936 = 1
24 May 2015 16:55 #32936 by ursus69
Please, I need help...
I update to the nightly....and my switch mod works ok.
But my nRF24L01 module and the A7105 NO WORKS!.... in the model setup, the protocol (Flysky, Hubsan4,etc..) appears with an *, and only Re-Init.....and I can´t bind and nothing..
With deviation 4.0.1 worked fine...
This is my hardaware.ini
Two modules are activated...
What is the problem??
Any solution?
24 May 2015 17:16 #32937 by Arakon
According to your .ini, they are NOT active. You have to remove the semicolon in front of the lines that you want to activate.
24 May 2015 18:04 #32938 by PhracturedBlue
Replied by PhracturedBlue on topic How to update?
remove the semicolons for lines that you want enabled. they make the code ignore the line.
24 May 2015 18:21 #32939 by ursus69
Oks, noob error :P
Thanks Arakon and PhracturedBlue!
Time to create page: 0.213 seconds
