Help, short circuit of the battery pack Devo 7
25 May 2015 21:18 #32981 by inmoss
Hi, I'm new to the forum and I have a problem with my devo 7 which comprises not normally after a short circuit of the battery pack (8x 1.2 v ) , where the wires were burned. Repaired and tested battery pack , connect it to devo 7 and this does not turn . it reviewed by the interior, no impairment is displayed . In support , I connected LIPO battery 7.2 V and surprise, the devo 7 IS ON, but brand battery level 0 . :P
Someone knows what could have happened , if something was damaged devo 7 or a battery pack makes cut
Test resistors images and mark well
26 May 2015 04:42 #32992 by Arakon
Check if the diodes around that area are still okay.
08 Jun 2015 10:39 #33625 by inmoss
Replace battery pack by 11.1 v lipo works well . All I had to reconfigure the radio as FMOD remained enabled by default. According manually configure MOD and now work well.
Time to create page: 0.111 seconds
