DEVO 12E white
- dlawso
13 Jun 2015 11:14 #33999
by dlawso
DEVO 12E white was created by dlawso
Hi I have a Devo-12E (white) and wanted to use the firmware from Devo12E TestBuild. Unfortunately, no USB logo only screen darker the so remained even switching off. By removing the battery then I could loaden the original firmware again. Can one help me?
13 Jun 2015 16:10 #34019
Replied by PhracturedBlue on topic DEVO 12E white
Hmm. I had hoped the 12E would use the same screen from the 10 (the internals look the same). Let me look into it some more and see what I can do.
27 Jun 2015 21:36 #34769
Sorry, I forgot to check on this.
I have looked it over, and I don't see anything obviously wrong. I uploaded a new 12e build but I doubt it will work any better. But if you are willing to try several builds, we can try to narrow down where the issue is.
- RedSleds
27 Jun 2015 22:18 - 27 Jun 2015 22:22 #34772
by RedSleds
Replied by RedSleds on topic DEVO 12E white
When I flashed deviation to my DEVO 10, I turned it on and the screen was extremely dim, couldn't see diddly-squat. I had to edit the tx.ini file so that I could see what was on the screen. I set the brightness (backlight) to 1, and the contrast to 10, to get what I thought were good settings.
You might try that, and save the edited tx.ini back to the Tx. Hopefully, that will work.
Last edit: 27 Jun 2015 22:22 by RedSleds.
27 Jun 2015 22:25 #34773
If the power switch doesn't work, then the problem is likely in the initialization routines somewhere, as the watchdog/switch monitor are started reasonably early in the process. Also, it is likely the USB mode isn't working either, so there is no tx.ini to monitor.
I would guess that I could get it fixed up in an hour or so if I had one in front of me. It is a lot harder to do through the internet.
- RedSleds
27 Jun 2015 23:21 #34776
by RedSleds
...but was the root folder of the Tx discovered by File Explorer on his PC when he attempted USB mode, and he just didn't look for it there?
Just thinking out loud here.
- dlawso
03 Jul 2015 10:21 #35049
by dlawso
Replied by dlawso on topic DEVO 12E white
Hey PhracturedBlue,
Unfortunately, it works with the new firmware does not. My display is dark and I can start the channel again after removing the battery.
03 Jul 2015 12:31 - 03 Jul 2015 12:46 #35053
Ok, let's try this:
deviationtx.com/downloads-new/category/1...est-build-usb-no-lcd
It doesn't turn the LCD on, but should light the backlight and switch into USB mode on power up. If that works, it will confirm the issue is isolated to the LCD driver. Let me know if that works.
Also the power switch should work
Last edit: 03 Jul 2015 12:46 by PhracturedBlue.
Time to create page: 0.827 seconds
- DEVO 12E white
