How to connect gyro with walkera rx
24 Jun 2015 20:54 #34606 by saad khan
How to connect gyro with walkera rx was created by saad khan
I ve already rx2702 but i am not satisfied from its working so pleas tell me that how can I install K bar 3 axis gyro to my tx.
25 Jun 2015 02:18 #34608 by Thomas.Heiss
Replied by Thomas.Heiss on topic How to connect gyro with walkera rx
Cant you just connect all servo ports to the receiver according to the manual? CCPM config.
Most FBL support a Spektrum satellite or digital signal (sbus, SRXL, Sumd/0,...) too which Walkera probably is not.
Well not that I have heard of that yet. Any input from others?
My personal suggestion: Get a Spektrum AR9020/9310 and use Spektrum SRXL (Spektrum DSMx on at least 100mw) to connect it to Spirit System FBL or MicroBeastPlus/Pro.
Sorry dont own Kbar or have vstabi setup experience.
25 Jun 2015 02:25 #34609 by saad khan
Replied by saad khan on topic How to connect gyro with walkera rx
you mean that K bar will not work with my walkera rx?
25 Jun 2015 10:21 #34633 by Thomas.Heiss
Of course you can't use your RX2702 with included / activated FBL.
Can you deactivate it and just use the servo ports? Well, makes no sense actually.
Probably you should get a normal Walkera receiver (without FBL) and sell your RX2702.
Or go the FHSS route...
25 Jun 2015 12:03 #34647 by saad khan
Should it will work then if i make the gyro gain zero.?
25 Jun 2015 12:33 #34648 by Thomas.Heiss
What gyro gain are you talking about? Tail gyro gain?
Any poti on the RX2702?
I do not think that this will turn off the FBL at all???
www.deviationtx.com/forum/3-feedback-que...-to-my-devo-rx#32585
What happend to your Walkera RX801?
25 Jun 2015 12:46 #34650 by saad khan
tail ,aile,elev gain zero.I ve connected the rx 801 to my another heli. and i am facing the problem with V18g01 which have rx2702.
Time to create page: 0.704 seconds
