DEVO8S switch
08 Jul 2015 00:09 - 08 Jul 2015 00:09 #35232 by dc59
DEVO8S switch was created by dc59
There are two switchs on DEVO8S , could it be assigned to some channel or function?
such as a switch of camera trigger or video trigger?
how to do it?
Thanks a lot!
Last edit: 08 Jul 2015 00:09 by dc59.
08 Jul 2015 03:44 #35241 by mwm
Replied by mwm on topic DEVO8S switch
Actually, there are four buttons (up and down on both sides) there. You can configure them - and the buttons around the LCD display - as either momentary or toggle buttons, or in pairs as on/off buttons, or even as an analog value using a pair as up/down buttons.
See the manual entry on using trim's as virtual switches for the real skinny, or the last section of my tutorial on writing model config files for some examples of use.
08 Jul 2015 07:43 #35244 by dc59
Replied by dc59 on topic DEVO8S switch
mwm wrote: Actually, there are four buttons (up and down on both sides) there. You can configure them - and the buttons around the LCD display - as either momentary or toggle buttons, or in pairs as on/off buttons, or even as an analog value using a pair as up/down buttons.
Is it correct ? Left trim = TRIM L- & L+ and Right trim = TRIM R- & R+
Thanks a lot.
08 Jul 2015 21:10 #35253 by mwm
Yup. The first four trim switches (eight buttons) are TRIMXDS: X is L for Left or R for Right, D is V for Vertical or H for horizontal, and S is either + or - for the up or down direction.
The last two trims (four buttons) are just TRIMDS, with the same D and S values.
09 Jul 2015 00:05 #35260 by dc59
Got it, thanks Mike!
10 Jul 2015 21:07 - 10 Jul 2015 22:29 #35309 by magic_marty
Replied by magic_marty on topic DEVO8S switch
trying this on my devo12 and no luck i followed the guide but when i flip the trim switch the servo i got hooked up as a test unit do nothing..:(
i don't understand where you select which output is activated when the switch is flipped...??
Got it...I was selecting the wrong src.. :oops:
Last edit: 10 Jul 2015 22:29 by magic_marty. Reason: solved
Time to create page: 0.150 seconds
