Will deviation solve my problem.
27 Jul 2015 15:56 #36165 by saad khan
Will deviation solve my problem. was created by saad khan
After converting to deviation ,Would I will be able to use my tx with Spektrum DSMX.?
27 Jul 2015 16:32 #36168 by Sero
Replied by Sero on topic Will deviation solve my problem.
What is the problem you want to solve with DSMX?
And again, as this is a double post, the answer is yes.
27 Jul 2015 18:08 - 27 Jul 2015 18:33 #36175 by saad khan
Replied by saad khan on topic Will deviation solve my problem.
I ve the spectrum receiver and want to use it in ikon. So just to know that why devo 10 not work with it. and is deviation solve my problem?
Last edit: 27 Jul 2015 18:33 by saad khan.
27 Jul 2015 18:30 #36176 by Thomas.Heiss
Replied by Thomas.Heiss on topic Will deviation solve my problem.
Devo / Devention supports the DEVO (3 channel DSSS) protocol only.
You would need to get a DEVO receiver and connect it to FBL Brain/Ikon.
Or you (better) go the DeviationTX route with the proper firmware version and use Spektrum telemetry / flightlog: www.deviationtx.com/forum/3-feedback-que...0-to-deviation#36173
Asking in two threads in parallel really makes no sense if its almost the same topic. It will not get you more attention.
Time to create page: 0.181 seconds
