- 7e NRF24L01 instalation failed "Missing modules"
- Multirotor Go
11 Oct 2015 02:29 #38706
by Multirotor Go
7e NRF24L01 instalation failed "Missing modules" was created by Multirotor Go
Hello.
So I installed this www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html following this www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
then went to hardware and erased the semicolons and I have this:
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A13 has_pa-nrf24l01 = 1
; enable-multimod = A13
I turn on the transmitter and get modules missing: NRF24101 at start up
I have rechecked all the wiring, everything is connected like in the pictures from the link. So I have no idea what is going on. Hope you can guide me to discover the problem or if this something that happens often and there is a fix.
thank you
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 0
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
thank you
- Multirotor Go
11 Oct 2015 02:47 #38708
by Multirotor Go
Replied by Multirotor Go on topic 7e NRF24L01 instalation failed "Missing modules"
now I have this in hardware
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 0
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
enable-nrf24l01 = A14 has_pa-nrf24l01 = 1
I changed the A13 to A14 but still it says module missing
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 0
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
- Arnold
11 Oct 2015 02:55 - 11 Oct 2015 02:56 #38709
by Arnold
I'm probably the last guy on this forum to be offering advice, but here's what I see:
The portion of your quote (above) that reads, "has_pa-nrf24l01 = 1" should be on a line by itself, I believe, rather than tagged onto the end of the previous line. See if changing that helps.
Replied by Arnold on topic 7e NRF24L01 instalation failed "Missing modules"
Multirotor Go wrote: ...
enable-nrf24l01 = A13 has_pa-nrf24l01 = 1 ...
Last edit: 11 Oct 2015 02:56 by Arnold. Reason: typo
- Multirotor Go
11 Oct 2015 03:07 - 11 Oct 2015 03:28 #38711
by Multirotor Go
thank you
well I don't think that matters, since actually in my editor I see everything on a single line. And I see here that it is shown as I see it on my editor at 15:15
Last edit: 11 Oct 2015 03:28 by Multirotor Go.
- Multirotor Go
11 Oct 2015 03:12 #38712
by Multirotor Go
I went back to A13 . I got confused. A13 is the correct one. still missing.
- Arnold
11 Oct 2015 03:31 - 11 Oct 2015 03:32 #38713
by Arnold
Ah, yeah, OK. Took my best shot, now I'm out of ammo
Multirotor Go wrote: ...l I don't think that matters, since actually in my editor I see everything on a single line...
Last edit: 11 Oct 2015 03:32 by Arnold. Reason: removed YT video - dupe
- SadSack
11 Oct 2015 03:55 #38714
by SadSack
It does matter how you edit ini file!
What you using to edit ini?
Replied by SadSack on topic 7e NRF24L01 instalation failed "Missing modules"
Multirotor Go wrote: thank you
- Multirotor Go
11 Oct 2015 04:03 #38715
by Multirotor Go
the default program that window 8 uses, the sames as in the video I posted.
- SadSack
11 Oct 2015 04:04 #38716
by SadSack
- SadSack
11 Oct 2015 04:12 #38717
by SadSack
Sure coders will give correct answer as to why it matter but to rest of us looking right don't make it so
Now still may not work....
Just reflux all solder joints and reflow solder. Looking for nice and bright solder.
- Multirotor Go
11 Oct 2015 04:19 #38718
by Multirotor Go
I replaced the hardware ini with one from a friend that has his devo 7e working with this modules and still is doe's not work. Maybe banggood send to me a bad one
That would mean to me like 2 more month to have a new one here. How can I know if the module is working ?
- SadSack
11 Oct 2015 04:28 #38719
by SadSack
Unfortunately module's can be doa but check install and solder joints..dry joints are just as likely as doa module!
- SadSack
11 Oct 2015 04:33 #38720
by SadSack
No easy way to test modules.
Would taking module out of the working tx an option? Or did you get bind and fly... Could get you going till replacement arrives.
- Multirotor Go
11 Oct 2015 04:42 #38721
by Multirotor Go
Nah to complicated to me. solder joint look ok, well they are far from perfect but still not that bad to the point were thing could not be recognized. I will re, re, recheck the thing and redo everything again it seems I don't have another option
- SadSack
11 Oct 2015 04:55 #38722
by SadSack
Take break, kick the cat.... Only joking
Honestly dry joints get everyone
- magic_marty
11 Oct 2015 04:59 - 11 Oct 2015 05:03 #38723
by magic_marty
Replied by magic_marty on topic 7e NRF24L01 instalation failed "Missing modules"
I had the exact same problem installing the nrf in a devo12 and no matter what was tried it would not work...i took the module out and put it in my devo8 and it worked fine i rechecked and rechecked and rechecked but it would never work and to this day it still does not work in my devo12....i bought a 12s and put the same module in it and it works perfect....never did figure out why the 12 would not accept the module...only thing i could figure is it is one of the early production devo12 models and there is something different about it versus the 12s...so i gave up on it and accepted defeat...
but the module is still working perfect in my 12s..
EDIT: Heads up you don't have to wait months to get a new module they are available here in the U.S i bought 2 off Ebay and they both work great....have one in my 12s and the other in my 8..
Last edit: 11 Oct 2015 05:03 by magic_marty. Reason: added more info..
- Multirotor Go
11 Oct 2015 05:16 #38724
by Multirotor Go
Well I am not from US and around here this exact module is not available. I have the 7e not the devo 12
mmm l will try to redo everything
and in the mean time order another module
11 Oct 2015 09:04 #38730
Replied by mwm on topic 7e NRF24L01 instalation failed "Missing modules"
Instead of trusting a 2 year old article on the hardware install, you might check the official documentation, which is updated regularly as the software changes:
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
In particular, the module wiring he use dates back to the 4.0.1 release, which doesn't use hardware.ini. It's been over a year since that was correct for the nightly build. While it can work with the old wiring, the exact behavior will depend on the protocol, and some have reception problems, possibly bad enough to cause binding issues.
- TomPeer
11 Oct 2015 10:17 #38731
by TomPeer
Replied by TomPeer on topic 7e NRF24L01 instalation failed "Missing modules"
as far as i know the wiring for the nrf module hasn't changed.
- Doug40
11 Oct 2015 14:44 #38738
by Doug40
I installed the same module using the same directions into my 7e sometime during the Spring of this year. It worked without any problems with the nightly builds available at the time. Some weeks or months later, I added an A7105 module (correct no. ??) and it gave me an indication similar to what you have. I checked it over and over, and all of the wiring was correct. Out of desperation, I changed the module position, A13/A14, by moving the wires at the CYRF module. After that it worked, and has continued through the current nightly builds.
I don't have a clue whether there was an problem I corrected by moving the two wires, or if there was a conflict with the nightly builds. It is probably a long shot, but possibly worth trying before you do something major.
Replied by Doug40 on topic 7e NRF24L01 instalation failed "Missing modules"
You can do a lot better than notepad.exe that comes with Windows, even though you are probably 100% correct with your changes. I found Notepad++, an open source editor that really works well for things like config files.Multirotor Go wrote: the default program that window 8 uses, the sames as in the video I posted.
Time to create page: 0.462 seconds
