- Objects to be placed at display: Limitations
- mabxhrc
- At each flight, a new brain connection...
26 Oct 2015 01:17 #39197
by mabxhrc
Objects to be placed at display: Limitations was created by mabxhrc
Hello everyone.
I have a doubt.
How many type objects "small box" I can put in same time in the 8S radio screen?
I'll explain:
- Radio Devo 8S.
- RX802.
- Telemetry walkera WK-CTL01-D.
- Ikon flybarless control.
- Trex 500 DFC.
What I need:
- View on the screen:
small box: ch1 / ch2 / ch4 / ch6 / timer1 / volt1 / rpm11
big box: CH3.
When I try to add a seventh small box and then try to save this profile, then to return to the main screen to see the newly placed object is deleted.
To profile the heli HK-500, I can put 09 small box and 02 big box with no problem.
Does the limitation is due to the use of more mixers in Trex500Dfc profile?
Devention Version: v4.01
Software works ok, I have programmed 03 helis: HK-500 flybar / Mini-cp and Trex500-DFC and made flight tests - everything is fantastic. is impressive ease of features that this software offers to program.
You are to be congratulated for the excellent job done.
Cheers!
Marcos
I have a doubt.
I'll explain:
- Radio Devo 8S.
- RX802.
- Trex 500 DFC.
What I need:
big box: CH3.
Cheers!
Marcos
26 Oct 2015 13:20 #39205
Replied by mwm on topic Objects to be placed at display: Limitations
In deviation, tere is a limit on the total number of "things" you can display. Small boxes, big boxes, trims, images - everything counts toward that limit. Try removing something else.
If you're actually using Walkera's devention software, then this doesn't apply.
- mabxhrc
26 Oct 2015 17:44 #39216
by mabxhrc
Oops, sorry about that. I put wrong firmware name: I talked about Deviation.
mwm; as you can see, this issue does occur only at Trex500Dfc profile. At HK500 profile I can put more than 6 small boxes.
Anyway, I will proceed as oriented..
Tks!
Replied by mabxhrc on topic Objects to be placed at display: Limitations
Tks!
- richardclli
27 Oct 2015 05:18 #39231
by richardclli
Replied by richardclli on topic Objects to be placed at display: Limitations
There is a limit to all elements in the screen you cannot have more than a total 27 elements. I tried in the nightly build and found that the no of boxes (big or small) can be more than 8.
- mabxhrc
27 Oct 2015 14:27 #39248
by mabxhrc
richardcli;
Thank you by your efforts and information provided.
So, maybe there a "bug" caused by this profile?
The switches mapping are:
RUD DR: Ikon flight bank selection 1/2
ELE DR: TImers Reset and Ikon flight bank selection 3
Gear: Ikon rudder gain
Flight Mode: Flight mode
AIL DR: Throttle Hold
My thought about to put those small boxes at display is to verify the sticks operation before start a new flight (for safety purposes).
At HK500 profile, I can do this without any issue.
name=## TREX500-DFC ##
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=8
fixed_id=410832
tx_power=10mW
[protocol_opts]
Telemetry=On
[channel1]
reverse=1
failsafe=0
scalar=123
scalar-=122
template=cyclic2
[channel2]
failsafe=0
scalar=118
scalar-=127
template=cyclic1
[channel3]
safetysw=Virt5
failsafe=-100
safetyval=-100
scalar-=100
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=9point
points=-100,65,67,68,69,71,77,83,100
smooth=1
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=9point
points=100,91,83,75,70,75,83,91,100
smooth=1
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=9point
points=100,94,87,85,80,85,89,94,100
[mixer]
src=THR
dest=Ch3
switch=RUD DR1
scalar=60
usetrim=0
curvetype=fixed
smooth=1
[channel4]
reverse=1
failsafe=0
scalar=123
scalar-=124
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=35,35
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=20,20
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=20,20
[channel5]
template=expo_dr
[mixer]
src=GEAR0
dest=Ch5
scalar=60
curvetype=fixed
[mixer]
src=GEAR0
dest=Ch5
switch=GEAR1
scalar=65
curvetype=fixed
[channel6]
failsafe=50
scalar=122
scalar-=112
template=cyclic3
[channel7]
failsafe=0
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=-100
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=RUD DR1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=ELE DR1
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=20,20
[mixer]
src=AIL
dest=Virt1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Virt1
switch=FMODE2
curvetype=expo
points=15,15
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=35,35
[mixer]
src=ELE
dest=Virt2
switch=FMODE1
curvetype=expo
points=20,20
[mixer]
src=ELE
dest=Virt2
switch=FMODE2
curvetype=expo
points=20,20
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
points=-18,-18,7,31,50,60,70,78,85
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
points=-60,-25,1,27,50,63,77,92,100
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=9point
points=-100,-75,-50,-25,0,25,50,75,100
[mixer]
src=THR
dest=Virt3
switch=!AIL DR0
curvetype=9point
[mixer]
src=Virt3
dest=Virt3
switch=RUD DR1
scalar=65
usetrim=0
curvetype=fixed
[mixer]
src=THR
dest=Virt3
switch=ELE DR1
usetrim=0
curvetype=9point
points=-29,-10,9,29,42,54,67,75,90
[virtchan4]
name=SAFE SET
template=cyclic3
[virtchan5]
name=STTH
template=complex
[mixer]
src=Virt5
dest=Virt5
usetrim=0
curvetype=min/max
points=0
[mixer]
src=Ch3
dest=Virt5
offset=-1
usetrim=0
muxtype=add
[mixer]
src=AIL
dest=Virt5
switch=AIL DR1
usetrim=0
curvetype=fixed
[virtchan6]
name=RETH
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=Ch3
resetsrc=ELE DR1
time=360
[timer2]
src=Ch3
resetsrc=ELE DR1
[telemalarm1]
source=Volt2
above=1
value=200
[telemalarm2]
source=Volt1
above=1
value=48
[telemalarm3]
source=Temp1
value=50
[telemalarm4]
source=Temp2
value=50
[telemalarm5]
source=Temp3
value=50
[datalog]
switch=None
rate=1 sec
source=Timer1
source=Timer2
source=TelemV1
source=TelemV2
source=TelemT1
source=TelemT2
source=AIL
source=ELE
source=THR
source=RUD
source=RUD DR0
source=RUD DR1
source=ELE DR0
source=ELE DR1
source=AIL DR0
source=AIL DR1
source=GEAR0
source=GEAR1
source=MIX0
source=MIX1
source=MIX2
source=FMODE0
source=FMODE1
source=FMODE2
source=Ch1
source=Ch2
source=Ch3
source=Ch4
source=Ch5
source=Ch6
source=Ch7
source=Virt1
source=Virt2
source=Virt3
[safety]
Auto=min
[gui-320x240]
V-trim=127,75,1
H-trim=6,220,3
V-trim=185,75,2
H-trim=191,220,4
Big-box=9,34,Timer2
Big-box=9,74,Timer1
Small-box=9,114,TelemV2
Small-box=9,139,TelemRPM1
Toggle=143,32,1,64,128,FMODE
Toggle=143,66,193,192,0,AIL DR
Toggle=144,101,8,71,0,RUD DR
Small-box=204,191,Ch4
Small-box=203,43,Ch2
Small-box=203,69,Ch1
Small-box=203,95,Ch6
Big-box=203,145,Ch3
Regards!
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=8
fixed_id=410832
tx_power=10mW
[protocol_opts]
Telemetry=On
[channel1]
reverse=1
failsafe=0
scalar=123
scalar-=122
template=cyclic2
[channel2]
failsafe=0
scalar=118
scalar-=127
template=cyclic1
[channel3]
safetysw=Virt5
failsafe=-100
safetyval=-100
scalar-=100
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=9point
smooth=1
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=9point
smooth=1
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=9point
[mixer]
src=THR
dest=Ch3
switch=RUD DR1
scalar=60
usetrim=0
curvetype=fixed
smooth=1
[channel4]
reverse=1
failsafe=0
scalar=123
scalar-=124
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=35,35
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=20,20
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=20,20
[channel5]
template=expo_dr
[mixer]
src=GEAR0
dest=Ch5
scalar=60
curvetype=fixed
[mixer]
src=GEAR0
dest=Ch5
switch=GEAR1
scalar=65
curvetype=fixed
[channel6]
failsafe=50
scalar=122
scalar-=112
template=cyclic3
[channel7]
failsafe=0
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=-100
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=RUD DR1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=ELE DR1
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=20,20
[mixer]
src=AIL
dest=Virt1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Virt1
switch=FMODE2
curvetype=expo
points=15,15
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=35,35
[mixer]
src=ELE
dest=Virt2
switch=FMODE1
curvetype=expo
points=20,20
[mixer]
src=ELE
dest=Virt2
switch=FMODE2
curvetype=expo
points=20,20
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=9point
[mixer]
src=THR
dest=Virt3
switch=!AIL DR0
curvetype=9point
[mixer]
src=Virt3
dest=Virt3
switch=RUD DR1
scalar=65
usetrim=0
curvetype=fixed
[mixer]
src=THR
dest=Virt3
switch=ELE DR1
usetrim=0
curvetype=9point
[virtchan4]
name=SAFE SET
template=cyclic3
[virtchan5]
name=STTH
template=complex
[mixer]
src=Virt5
dest=Virt5
usetrim=0
curvetype=min/max
points=0
[mixer]
src=Ch3
dest=Virt5
offset=-1
usetrim=0
muxtype=add
[mixer]
src=AIL
dest=Virt5
switch=AIL DR1
usetrim=0
curvetype=fixed
[virtchan6]
name=RETH
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=Ch3
resetsrc=ELE DR1
time=360
[timer2]
src=Ch3
resetsrc=ELE DR1
[telemalarm1]
source=Volt2
above=1
value=200
[telemalarm2]
source=Volt1
above=1
value=48
[telemalarm3]
source=Temp1
value=50
[telemalarm4]
source=Temp2
value=50
[telemalarm5]
source=Temp3
value=50
[datalog]
switch=None
rate=1 sec
source=Timer1
source=Timer2
source=TelemV1
source=TelemV2
source=TelemT1
source=TelemT2
source=AIL
source=ELE
source=THR
source=RUD
source=RUD DR0
source=RUD DR1
source=ELE DR0
source=ELE DR1
source=AIL DR0
source=AIL DR1
source=GEAR0
source=GEAR1
source=MIX0
source=MIX1
source=MIX2
source=FMODE0
source=FMODE1
source=FMODE2
source=Ch1
source=Ch2
source=Ch3
source=Ch4
source=Ch5
source=Ch6
source=Ch7
source=Virt1
source=Virt2
source=Virt3
[safety]
Auto=min
[gui-320x240]
V-trim=127,75,1
H-trim=6,220,3
V-trim=185,75,2
H-trim=191,220,4
Big-box=9,34,Timer2
Big-box=9,74,Timer1
Big-box=203,145,Ch3
Regards!
- mabxhrc
28 Oct 2015 02:15 #39278
by mabxhrc
I did the same settings in the emulated nightly build module and everything worked normally.
In your opinion the nightly builds firmware releases are safe for use in actual flights?
Cheers.
richardclli wrote: There is a limit to all elements in the screen you cannot have more than a total 27 elements. I tried in the nightly build and found that the no of boxes (big or small) can be more than 8.
Cheers.
- richardclli
28 Oct 2015 09:17 #39288
by richardclli
I have not yet tried a real flight with the current nightly build, however I am planning to test it thoroughly and see is there are any more bugs.
But I have heard that many other has tried to use the nightly and confirmed to be stable. So I think it is up to your choice to try it out or not.
Time to create page: 0.172 seconds
