Adding Model configs?
17 Jan 2016 15:39 #41870 by kchupe
Adding Model configs? was created by kchupe
I have never used Deviation before and don't understand how to install model configurations from this site. How do I install a model config on my Devo 10?
17 Jan 2016 18:26 #41878 by Jasenk
Replied by Jasenk on topic Adding Model configs?
This is DEVO10 directions. I'm not positive about all others. Once you've upgraded your TX it will be a USB drive. On the USB drive there will be a "Models" folder. See attachment. You copy and paste the Model#.ini (Model##.ini if it's 10 and over) into that folder. Name it with a number that is open. So if model5.ini is not being used rename the file you want to use to model5.ini and paste over the old file.
Have fun! I do.
-Jasen
Time to create page: 0.193 seconds
