please help deviation newbie
14 Apr 2016 13:37 #46491 by DeeRod
please help deviation newbie was created by DeeRod
ok got my radio all put back together installed dfuse usb tool and ugraded to latest nightly build then i copy and pasted everything into my devo and got rid of the (-)'s on a7105 and on nrf24101 and now when i try to do model set up and choose v202 it just sais re init but dsm2 and dsmx say bind what could i have done wrong does this mean i installed my modules wrong or installed faulty ones any help would be great havent bin able too sleep cause of this thing
14 Apr 2016 14:05 #46492 by TheSFReader
Replied by TheSFReader on topic please help deviation newbie
As far as I understand, bind and reinit are dependant on the protocol, so it's not necessarily an error that you get different values depending on the protocol you want to use.
If I have it right, Bind establishes a persistant bind between the Tx and the model, which would resume after both being restarted, while reinit is just the transmitter getting reinitialized and sending an initial sequence on which the model hooks up "until the next model power cutoff".
If the model/protocol you use needs a real bind, you would need to follow the binding procedure on both the Rx and the Tx.
14 Apr 2016 14:31 #46493 by DeeRod
Replied by DeeRod on topic please help deviation newbie
ok soo if its not binding to the quad whats my problem then like too me it appears i have everything right if what your saying is tru the first protocols like devo,WK2801 ect.... dsm2, dsmx, and J6pro all say bind and all the toy brand quad protocals all say reinit and i cant get it too bind to my jj1000 is there some bind procedure im missing or did i mess up the install even though i checked for shorts with an ohm meter and continuity or did i muc up in the software install sorry im trying to give as much information as i can. if there is something else you need to know to help you help me please let me know. thank for your time guys
14 Apr 2016 14:56 #46496 by TheSFReader
So, if I get it right, you enabled the nrf module, it's detected correctly (no warning at startup for a missing module ?), you configured the Tx to use a model with the V2x2 protocol. Right ?
As far as I understand, the procedure from there would be to power off the quad and the tx, power on the quad (which should signal it is ready to (pseudo)bind), and power on the tx.
Does that fail ?
14 Apr 2016 15:03 #46497 by DeeRod
Yes you are correct soo theres a warning for improper module install and/or faulty warning thats cool didnt know. Is there something else i can try?
14 Apr 2016 15:14 #46498 by TheSFReader
If there are warnings of missing modules, it seems the custom here is to publish the hardware.ini file and post picturesof the modules installation/soldering so people can help you check where the fault might be.
14 Apr 2016 15:42 #46499 by DeeRod
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enablea7105 = A13
; has_paa7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enablenrf24l01 = A14
; has_panrf24l01 = 1
; enable-multimod = A13
is this right?
14 Apr 2016 15:43 #46500 by DeeRod
just soo i dont have to tear apart my transmitter right off the bat was a little tricky
14 Apr 2016 16:35 #46501 by DeeRod
and i just tried to put pictures up and every time i submit it just loads for a while then it bring me back to the forum and nothing got posted 2 times now man this stuff is frustration almost ready to smash this thing :woohoo:
14 Apr 2016 16:48 #46502 by FDR
Replied by FDR on topic please help deviation newbie
DeeRod wrote: and i just tried to put pictures up and every time i submit it just loads for a while then it bring me back to the forum and nothing got posted 2 times now man this stuff is frustration almost ready to smash this thing :woohoo:
There is a size and dimension limit, and it warns you about that , but the message is at the top of the page...
The limit is 1MB and probably 1024*1024px if I recall it well.
14 Apr 2016 16:54 #46503 by TheSFReader
There is already one problem I spotted on your hardware.ini file : you ned to put back the '-' and supppress the ';' instead.
Additionally, since we can't (yet) see where you linked the csn for the two modules, we can't check if you didn't interchange them, in which case you would need to switch the 7105's A13 by the NRF's A14 and vice-versa You'll need to check that if the hardware.ini correction doesn't do the trick.
14 Apr 2016 16:58 #46504 by DeeRod
14 Apr 2016 17:03 #46505 by DeeRod
14 Apr 2016 17:07 #46506 by DeeRod
sorry what do you mean by suppress the *;*
14 Apr 2016 17:12 #46507 by DeeRod
ok now i have a missing a7105 so this means i messed up wiring correct? and by the way thank you very much you have been extremly helpful i thought all was lost :/
14 Apr 2016 17:28 #46508 by DeeRod
ok just to test and see if i could just use the nrf24101 module i unplugged my a7105 and put the ; back on where the a7105 is on the harware ini and it still sais missing a7105 module whats going on here?
14 Apr 2016 17:29 #46509 by magic_marty
Replied by magic_marty on topic please help deviation newbie
i think you need to remove the ; on the modules you installed ...mine looks like this i only have the NRF module installed...
;enable-haptic=1
;extra-switches=
; extended_audio: audiofx, dfplayer (dfplayer not supported yet)
;extended-audio=
[modules]
; enable-a7105 = A13
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
enable-nrf24l01 = A13
has_pa-nrf24l01 = 1
14 Apr 2016 17:31 #46510 by DeeRod
i was dumb to think that this wasnt going to be difficult deff a little over my head someone enlighten me lol
14 Apr 2016 17:32 #46511 by TheSFReader
"suppressing the ';' "was remove the first character on the line (which happens to be ';' and makes the devo ignore the line --> the module's configuration.
As for the pictures, I've no good knowledge of transmitters other than the 7e, so will leave knowledgeable people ones give answer that part. (But liiks like we miss details on the color code you use, the "distribution board" you've made (that square thingie), the pins it's connected to on the tx's board.
Still, if only the 7105 module is found out as missing, you should be able to use your model (which uses the NRF module), I'd check that first.
(Make sure the modules have antenna on any time they are powered!)
14 Apr 2016 17:37 #46512 by DeeRod
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
Time to create page: 1.301 seconds
