please help deviation newbie
14 Apr 2016 17:39 #46513 by DeeRod
Replied by DeeRod on topic please help deviation newbie
ok i guess i messed up the wiring because with that ini its telling me my nrf24101 is missing soo im assuming i should try resolders directly to the controller?
14 Apr 2016 17:42 - 14 Apr 2016 17:43 #46514 by TheSFReader
Replied by TheSFReader on topic please help deviation newbie
The file looks much better.
If you connected the module CSN signal to TMS pin in your transmitter, the value should be A13. If you instead connected it to the TCK pin, the value should be set to A14.
As I wrote earlier, if you switched the CSN lines, you should switch the A13/A14
Last edit: 14 Apr 2016 17:43 by TheSFReader.
14 Apr 2016 17:58 #46515 by DeeRod
omg you guys are my heros i cant even explain how many times i was almost in tears because of this thing thank you soo soo much guys
14 Apr 2016 18:05 #46516 by DeeRod
lol to think all i needed was to swap numbers around i was doubting all my double checks and tripple checks thanks soo much again lol
14 Apr 2016 18:31 #46517 by TheSFReader
So it works ? Great !)
14 Apr 2016 19:07 #46519 by DeeRod
yes it works but now when i assign channel 5 and go too the control monitor it doesnt move i took the remote apart again to see if it was unplugged and everything seems too be hunkydory i even tried shorting it out on the switch tabs and still nothing does this mean after all this is my devo a dud?
14 Apr 2016 19:17 #46520 by DeeRod
yep deff not the switch checked it with my meter and everything is good is there an ini i have to change?
14 Apr 2016 19:18 #46521 by DeeRod
or do i need to buy another Devo?
14 Apr 2016 20:45 #46526 by DeeRod
nevermind very sorry need too read more before i start asking for help just didnt know how to fully turn on the 5 channel again thanks for your time everyone
14 Apr 2016 23:02 #46532 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic please help deviation newbie
Best place to check physical inputs is under the Input Monitor rather than the Channel Monitor, that should show whether your physical switches/sticks are working and recognised, from there you have to decide how you want those physical inputs to be reflected in a channel.
Channels are completely and utterly independent of any physical input; they can have no pysical inputs assigned whatsoever, or they can have every single physical thing you have on your transmitter all mushing together to give a single output channel :silly: :blink:
15 Apr 2016 02:07 #46537 by mwm
Replied by mwm on topic please help deviation newbie
DeeRod wrote: ;Only useful for transmitters with an after-market vibration motor
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enablea7105 = A13
; has_paa7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enablenrf24l01 = A14
; has_panrf24l01 = 1
; enable-multimod = A13
is this right?
No. You removed the "-" on the nrf24l01 line and didn't uncomment it. The line should read "enable-nrf24l01 = A14" with no semicolon in front of it. With that setup,. you won't get a warning, but all your nrf protocols will have a "*" in front of the name, meaning they aren't available.
You get "Bind" on protocols that support model binding if it's enabled. That typically means you've input a model id. Usually a good idea if your protocol supports it.
Time to create page: 0.422 seconds
