original replacement module Devo 10 w
15 Apr 2016 06:18 - 15 Apr 2016 06:20 #46545 by DeeRod
hi i was just wondering if there is a place that sells the original cyrf6936 module i couldn't find one just searching around google. or if any one could tell me if theirs one thats better. but mainly i would like the original because its nice and easy too change. the only reason im asking is im afraid i might have damaged mine as i forgot to have the antenna on it when i turned it on for usb mode to link up to the computer it was only on for like 15-20 seconds before i turned it off and put it on. Do the modules still turn on when you turn it on in usb mode? Any help would be much appreciated :)
Last edit: 15 Apr 2016 06:20 by DeeRod.
15 Apr 2016 07:22 #46548 by dc59
15 Apr 2016 19:41 #46581 by DeeRod
Replied by DeeRod on topic original replacement module Devo 10 w
and that guy plugs in with no mods or any fancy programing? and still was wondering if the modules still work when the remote is turned on in usb mode?
16 Apr 2016 06:25 #46596 by DeeRod
please just want to know if this WK-DEVO-S-MOD just drops into the devo 10 w or is there wiring that needs to be done and if soo could someone show me the link please
16 Apr 2016 06:51 #46597 by Seven5555
Replied by Seven5555 on topic original replacement module Devo 10 w
this is a pic of the connections for the 7e.
16 Apr 2016 07:10 #46601 by DeeRod
it looks like it would plug right in so maybe im asking a stupid question i just dont want to buy it and plug it in and fry it when i turn it on because the pins where in a diff order
16 Apr 2016 08:37 #46608 by TomPeer
Replied by TomPeer on topic original replacement module Devo 10 w
In the Devo 10 it just plugs in.
There are 2 screws near the antenna you have to unscrew first. then remove the antenna, then you can take the old module out and the new one in.
plug the antenna back on the new module and put the screws back in.
The modules are the same.
16 Apr 2016 19:16 #46642 by DeeRod
thank you very much just wanted to order a spare or 2 just in case they stop making modules or i wreck mine if i havent already lol
01 Sep 2016 17:15 #53381 by jonrev
Replied by jonrev on topic original replacement module Devo 10 w
Just for UK readers wanting this module there's a seller called Cheap Drones UK which offer them at £13.60 inc post which is less than the total from Walkera and faster delivery (I would guess since I have only just sent my order).
Cheaper still is Banggood (£11 + change?) but likely a longish wait to get it.
Time to create page: 1.118 seconds
