Devo 10 + DSMX Telemetry?
- Batista16
24 Apr 2016 21:57 #47122
by Batista16
Devo 10 + DSMX Telemetry? was created by Batista16
Hey guys,
I have a Devo 10 with Deviation 3 (I haven't felt the need to update) and I'm trying to configure voltage telemetry.
My tx is an orangerx R720X v2, witch has connections directly to telemetry.
I plugged the telemetry voltage leads in the RX, and on the TX what I did was,enter Model setup, enter on DSMX protocol, set telemetry on.
Now on transmitter menu, monitor telemetry, it should show up the voltage on one of the sensors.
Do you see anything wrong? is there something else I need to configure?
- Alexandro
25 Apr 2016 07:50 #47144
by Alexandro
Replied by Alexandro on topic Devo 10 + DSMX Telemetry?
Hello, try to use the latest Nightly Build for the 10
3.X is very old.
My Orange r620x is working with Devo10 and latest Nightly Build.
-> If you missing some Telemetry Data , then search at the Telemetry Main Page Setup on Model Menu. There you can change and add the Boxes on the Main Screen to show your Data.
greetings Alex
3.X is very old.
greetings Alex
- Thomas.Heiss
- Batista16
25 Apr 2016 11:42 #47149
by Batista16
Replied by Batista16 on topic Devo 10 + DSMX Telemetry?
Thank you for your replies!
However, I just updated to the latest nightly (deviation-devo10-v4.0.1-becf9bd) and I still don't get any values.
Just to make sure we are on the same page, I have an OrangeRx with telemetry ports, I just plugged the volt telemetry to my power distribution board:
And on transmitter I didn't do much, I just enabled telemetry on model setup (click enter on DSMX) and thats it.. When I look in "Telemetry monitor" no values are returned (all zeros).
Here is my model: (I don't know if it's helpful)
name=250 QUAD
mixermode=Advanced
type=plane
[radio]
protocol=DSMX
num_channels=7
fixed_id=123456
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=ELE DR1
dest=Ch5
curvetype=min/max
[channel6]
template=simple
[mixer]
src=GEAR0
dest=Ch6
curvetype=min/max
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=-10
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=-100
[timer1]
type=permanent
src=THR
val=1562599
[timer2]
src=THR
[telemalarm1]
source=Volt1
value=0
[telemalarm2]
source=Volt2
value=0
[telemalarm3]
source=Volt3
value=0
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch3
box2=Timer1
box3=Timer2
box4=TelemV1
box5=TelemV2
box6=TelemV3
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=0,1,0
toggle2=AIL DR
tglico2=0,0,0
toggle3=RUD DR
tglico3=0,2,0
toggle4=GEAR
tglico4=0,4,0
quickpage1=Telemetry monitor
name=250 QUAD
mixermode=Advanced
type=plane
[radio]
protocol=DSMX
num_channels=7
fixed_id=123456
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=ELE DR1
dest=Ch5
curvetype=min/max
[channel6]
template=simple
[mixer]
src=GEAR0
dest=Ch6
curvetype=min/max
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=-10
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=-100
[timer1]
type=permanent
src=THR
val=1562599
[timer2]
src=THR
[telemalarm1]
source=Volt1
value=0
[telemalarm2]
source=Volt2
value=0
[telemalarm3]
source=Volt3
value=0
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch3
box2=Timer1
box3=Timer2
box4=TelemV1
box5=TelemV2
box6=TelemV3
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=0,1,0
toggle2=AIL DR
tglico2=0,0,0
toggle3=RUD DR
tglico3=0,2,0
toggle4=GEAR
tglico4=0,4,0
- mickkn
25 Apr 2016 12:10 - 25 Apr 2016 12:13 #47151
by mickkn
Replied by mickkn on topic Devo 10 + DSMX Telemetry?
I assume you have binded the RX with Telemetry support. (only BIND plug iirc)
And added the Volt2 as a box on the menu
Worked for me
Try change "box5=TelemV2" to box5=Volt2
I got this
Small-box=80,21,Volt2
Worked for me
I got this
Last edit: 25 Apr 2016 12:13 by mickkn.
- Batista16
25 Apr 2016 17:34 #47171
by Batista16
There is more than one way of binding?
I'm running s.bus, so to bind I move the Flight Controller plug to Throtle (to give power) and put the bind plug on Bind, and then I move the FC plug to the Bind port.
I didn't have it on screen but it shouldn't matter I think.. But I'll try that.
- mickkn
25 Apr 2016 17:37 - 25 Apr 2016 17:38 #47172
by mickkn
That can be the issue. If you want to disable the Telemetry on the RX. You will need 2 bind plugs. One in the BIND and one in the THR output. And if the SBUS connector is grounded (inside the FC) when powering up, it will disable the Telemetry.
www.hobbyking.com/hobbyking/store/upload...649612X893272X11.pdf
So try with another port than THR to power it
Last edit: 25 Apr 2016 17:38 by mickkn.
- Batista16
25 Apr 2016 17:42 #47173
by Batista16
Oh I see.. :l I'll rebind in another port..
- Batista16
08 May 2016 15:52 #48040
by Batista16
Hi guys, just to close this, i managed to make it work but a very strange thing is happening. If I have telemetry ON on the TX, I can't bind the RX in Telemetry mode! it simply does not bind. I think this is probably a bug(?).
What I had to do is turn OFF telemetry on TX and Bind RX in telemetry mode, and then turn on Telemetry in TX. then it all worked good.
- Cereal_Killer
08 May 2016 16:25 #48046
by Cereal_Killer
Replied by Cereal_Killer on topic Devo 10 + DSMX Telemetry?
To clarify you moved the power supply servo connector to ANY OTHER port (EXCEPT THROTTLE) during bind correct?
- Batista16
08 May 2016 18:50 #48061
by Batista16
Yes,
Binding with power on throttle works with tx telemetry on and off but no telemetry feedback gets through,
Binding with power on other port only binds if i turn telemetry off on the TX, and this way I can get telemetry feedback (once I turn it on after the binding process),
Binding with power on other port then throttle and telemetry ON on the TX always fails.
- Devo 10 + DSMX Telemetry?
