help with 5.0.0-99 on 7e
05 May 2016 20:38 #47835 by skretchmer
help with 5.0.0-99 on 7e was created by skretchmer
i have tried several times to load 5.0.0-99aee1a on my Devo 7e. I follow the directions exactly, format the drive, copy over the folder contents, etc... But when I go to use it my controller shuts off randomly, within a few minutes of being turned on. I can revert back to nightly build 4.0.1_aa82a64 with no troubles, and it works fine. I do have a fully populated Multi-Module, and I am making new changes to the hardware.ini file that I copy over from the 5.0.0aee1a folder, not the old hardware.ini file from 4.0.1. The module works fine when I revert back to 4.0.1.
any ideas anyone?
05 May 2016 21:45 #47839 by HappyHarry
Replied by HappyHarry on topic help with 5.0.0-99 on 7e
once it crashes is there any info inside the error.txt file? if so post it's contents and a description of the issues here bud >> www.deviationtx.com/mantisbt/my_view_page.php
05 May 2016 22:36 #47842 by skretchmer
Replied by skretchmer on topic help with 5.0.0-99 on 7e
Hmmm..
Ok, I tried the whole procedure again, and was able to get 5.0.0_99 installed and working, Except. When I go into the menu, the selected option is blank now. if I scroll up or down, the blank line moves, and replaces the selection.
better for sure..
06 May 2016 02:13 #47850 by hexfet
Replied by hexfet on topic help with 5.0.0-99 on 7e
This issue came in with commit 8bdf866. I've made a fix but can't currently make a PR because I messed up the master branch in my fork and still trying to fix it. Anyone feel free to go ahead :)
There's still a couple cosmetic differences even with this fix.
Time to create page: 0.227 seconds
