Frsky D8 Telemtry
08 May 2016 16:11 #48043 by Alexandro
Frsky D8 Telemtry was created by Alexandro
To Day im converting some of my Sailplanes from Taranis to Deviation.
Im using most Time Alt and Vspeed from the High prez. Vario ( the original Frsky Version )
Now i found some Things:
8 Channels only
Alt shows High over Sea Level
Vspeed is not implemented
Can some one please insert the same Telemetry Code like the FrskyX Protocol ?
Alt is going to Zero at Power up
VSP is the Vario Climb Rate
DIS is discharge with Amp Sensor
12 Chanel SBUS
If some one needs Testing, i can do it.
I have Amp Sensor, Vario,D8r,D4r,SBUS to PWM, Senso Hub with normal Altimeter ,AD2 Divider.
greetings Alex
08 May 2016 16:39 #48049 by Arakon
Replied by Arakon on topic Frsky D8 Telemtry
SBUS is receiver-sided, that can't be added on the transmitter. Same with the channel count.. with 8 channels, the PPM signal is "full". A receiver modification would be needed to add more.
08 May 2016 18:23 #48058 by Alexandro
Replied by Alexandro on topic Frsky D8 Telemtry
Oh, yes there i was wrong with the SBUS.
D Series do not have the SBUS Port.
08 May 2016 18:56 #48062 by hexfet
Replied by hexfet on topic Frsky D8 Telemtry
Alex, are you testing with the FrskyX test build? The telemetry changes there should be in Frsky protocol as well - they share the decoding code now. I did not change the AD2GAIN in Frsky though.
09 May 2016 05:06 #48091 by Alexandro
Oh, nice. :)
I was using a spare Tx and do not have seen it, time to flash it with your Frskyx Build
Thank You
09 May 2016 07:04 #48094 by blackmoon
Replied by blackmoon on topic Frsky D8 Telemtry
I'm interested in your findings Alexandro, I want to convert my fleet to Frsky and waiting for a DR4 and vario from Hobbyking for testing (Singapore post sucks big time :( )
09 May 2016 11:04 - 09 May 2016 11:06 #48102 by Alexandro
@blackmoon
i used the FrskyX Build to get the Telemetry for Frsky D8, but it does not work.
All new Telemetry Numbers do have a Black Background on Main Screen and showing 0.
I write some o.t Infos for hexfed at the FrskyX Post.
Maybe he can make some Changes to get it to work.
I use many D8R and D4R with Altimeter Vario on my Sailplanes and try to Change most of them to DeviatonTX.
greetings Alex
Last edit: 09 May 2016 11:06 by Alexandro.
09 May 2016 17:33 #48124 by hexfet
Alex, which tx are you using for the D8 testing? As with D16 the 7e only supports the rx telemetry, not hub. Are the RSSI and Volt1 values shown correctly?
The D8 telemetry seems to work fine in the emulator, so might need to make some debug versions for testing.
09 May 2016 17:59 - 09 May 2016 18:07 #48126 by Alexandro
i was using the Devo 10 with ver 070
RSSI and Volt1 is ok, but the other things do only show 0 and black Background.
Same on Devo 8S
greetings Alex
Last edit: 09 May 2016 18:07 by Alexandro.
09 May 2016 19:25 - 09 May 2016 23:55 #48133 by hexfet
Found an error in the D8 telemetry state machine - hope it's the problem.
The FrskyX test build is updated - 8e0 1bb.
Edit: test build updated with new 320x240 (color screen) telemetry test page.
Last edit: 09 May 2016 23:55 by hexfet.
10 May 2016 06:10 #48147 by Alexandro
Test Ver. 1bb on DEVO 8s
Nice Telemetry Test Screen :) !
Alt is most Time Jumping around , 52, 24, 42 and so one ( some error at getting the right conversion ? )
Amp is most tim ok (0.5, 0.6 <- is it doing double the original ? same at FrskyX -> 250 is around 600 at Display) but some times it jumps up to 700,1200, 72
Dis is ticking and looking good ( with the to high Amp it is not showing the right Number, but i looks it does the calc. good )
Vsi is the same as Amp
greetings Alex
-> should we do the debug here or want You have it on the FrskyX Post ? hexfed
10 May 2016 23:15 - 10 May 2016 23:17 #48179 by hexfet
Test build frskyx3 is updated - 278.
- Hub telemetry reworked based on opentx
The code in opentx was different than the documentation I've found online which was different from the old frsky code. Let's see how this looks before looking at the VOLTA difference. This may even fix that depending on what sensor IDs are being received. Would you mind listing the sensors you have hooked up?
If the values are jumping around it's likely a different issue than if they just have the wrong value.
Two new hub telemetry items are added - VARIO (VSI), and VFAS (VOLT3). Not sure if VFAS is different than the "amp sensor" but it has a different ID.
Probably best to continue the discussion here so it's clear this is about D8 and hub telemetry.
Last edit: 10 May 2016 23:17 by hexfet.
11 May 2016 07:26 #48190 by Alexandro
Test Ver. 278 on Devo 8s, D8R
Volt1 and RSSI looks good
all other Data are some times good and then jumping again.
i am using for testing:
FAS-100
Vari-H ( High prez. Altimeter ) as Hub for FAS-100
1/10 Divider for Volt2 ,for Testing Volt2 without the Vario ( it uses Volt2 for sending the Climb rate )
can get a FAS-40 for testing
greetings Alex
11 May 2016 12:09 #48196 by hexfet
Thanks Alex. Answers to these questions may help narrow it down.
1) Can you confirm you're only seeing values for the sensors you're using - all the other boxes are red with unchanging values, even when the sensor values jump around?
2) When the jumping occurs, does it happen to all the values at the same time or different sensors at different times?
3) When the jumping occurs, do the values stay close to the correct number, or does it seem random?
4) Does the Volt2 value stay steady, or does it jump around?
Also would you try FrskyX and check the VoltA and Amp readings there? Those values will be coming through the same decoding code.
One thing I haven't brought in from the opentx code yet is to only accept split sensor values (bp.ap) if they're received consecutively in sequence. Can add that tonight, but it's probably just there for the case of dropped packets. The opentx code also applies averaging to some of the sensors.
The Volt2 value comes from the same place in the packet as Volt1 so I'd expect the same behavior. If not that can rule out some possibilities.
11 May 2016 17:28 - 11 May 2016 17:29 #48214 by Alexandro
Test Ver. 278 , Devo 8s, D8R, Vario High Prez.,FVAS-100.
i have a Video where You can see it, it is hard to describe whats going on.
www.dropbox.com/s/s03noblkqpzt40l/d8r.mov?dl=0
the jumping is coming like Waves, You see it at Video
Test on FrskyX:
VoltA shows exact the input Voltage from the FVAS-100 and stay without any jumping
the AMP is showing 0.5 / 0.6 and no jumping, it is the same as on all working FrskyX Builds
Last edit: 11 May 2016 17:29 by Alexandro.
11 May 2016 23:09 #48236 by hexfet
Thanks! Video is very helpful.
Frskyx3 test build is updated - 209.
- Fixed error in indexing that caused last two bytes of telemetry packets to be skipped
- Only update baro altitude and amp sensor voltage if bp.ap parts received in order
The first item may fix the jumping around. Or it could be something else :) From the video seems like the same few erroneous values were being displayed.
The best info I found on D8 over-the-air packet format was this post . Anyone know of more detailed info, or SPI captures?
12 May 2016 14:31 #48276 by Alexandro
Test VER.209, Devo 8s, D8r
it is doing the same Dance
VoltA is showing 11 Volt ( this is the right Number) and the it jumps to 499 at some Time and later back to 11
Alt 2.4 , then 22.4 and then to an other wrong Number
the other Numbers doing same Things.
it looks like the Data Stream does not match the Data Fields some Time and blead into the wrong
neighbor Field, where it gets then wrong calculated
all other are red like same as on video
greetings Alex
12 May 2016 22:21 - 12 May 2016 22:21 #48304 by hexfet
Thanks Alex - appreciate your patience :)
I think you're right about data being written to the wrong place, but have not spotted the bug yet. Still looking but want to try something else at the same time.
I've put a special test version here for the devo 8s. It should save received telemetry packets into the datalog.bin file. It will start recording when telemetry is received, and can save about 20 seconds of data. No need to make any datalog settings on the tx. I've included an empty datalog.bin file in the zip for you to copy to the filesystem so it's a known starting point. So the test procedure is:
1) install the test dfu, then boot to usb mode and copy the datalog.bin file to the 8s
2) connect to the receiver (no need to rebind if already bound)
3) check that telemetry is being received
4) after 30 seconds power off the tx, boot to usb mode, and copy the datalog.bin file and post here
I doubt the data is the problem but want to be sure and it will be good to have some real test data.
This test dfu is not for flying! I tested it with another protocol on my devo10 and the datalogging worked, but it might cause issues...
Last edit: 12 May 2016 22:21 by hexfet.
13 May 2016 05:43 #48330 by Alexandro
the Datalog.bin, i renamed to Datalog.txt to upload it here
File Attachment:
File Name: datalog.txt
File Size:16 KB
greetings Alex
13 May 2016 11:35 - 13 May 2016 11:36 #48341 by hexfet
Great, it worked mostly :) Thanks
Did the jumping around symptom occur during the recording?
Last edit: 13 May 2016 11:36 by hexfet.
Time to create page: 0.123 seconds
