Help
25 May 2016 17:38 - 25 May 2016 17:40 #49209 by norris
Help was created by norris
Devo 7e won't go into USB mode, it bleeps and displays the folowing-
How do I get it to work now??
Last edit: 25 May 2016 17:40 by norris.
25 May 2016 19:08 #49213 by HappyHarry
Replied by HappyHarry on topic Help
what happened prior to this? did it ever work? what version of deviation have you installed etc etc etc
in other words we need more information
25 May 2016 19:38 - 26 May 2016 06:19 #49215 by norris
Replied by norris on topic Help
It work at one time but I could never get it to work fully with devation, it was fine with devention.
I was just having another attempt at loading deviation.
Last edit: 26 May 2016 06:19 by norris.
25 May 2016 20:02 #49218 by HappyHarry
what method are you using to try and flash the firmware and filesystem? please type it out step by step, also again which version of deviation did you use?
25 May 2016 22:17 #49228 by norris
Step by as manual for Devo 7e using drugs tool 2.0 (down loaded from the German site) and Deviation 5 on a windows Vista.
25 May 2016 23:45 #49233 by Deal57
Replied by Deal57 on topic Help
Make sure you flashed with the devo7e version, not the one with -emu in it. And you need to reflash. Hold down the EXT button while powering up, and tell us what you see.
26 May 2016 20:36 - 26 May 2016 20:39 #49323 by norris
Switching on I get "bad missing /Devo protocol" or words to that effect message no helicopter icon.
Thanks.
Last edit: 26 May 2016 20:39 by norris. Reason: Incorrect word
26 May 2016 20:57 #49326 by HappyHarry
are you remembering to copy across the filesystem including the protocols folder from the zip file you downloaded?
29 May 2016 17:58 #49514 by norris
There's an issue(virus?) with the protocol file.
I have a protocol folder on my desktop that I cannot remove and my computer is now packing up, problem is I needed and the information on it.
29 May 2016 18:57 #49517 by HappyHarry
where did you dowload the deviation file from? as the files hosted in the official downloads on this site are most definitely not infected with a virus
30 May 2016 14:37 #49569 by norris
The problem seems to be a file image of Yd717 in the protocol folder.
02 Jun 2016 17:57 #49832 by norris
I have managed to flash the firmware and load the beginners setting for my V120DO2S, however when I enter the adjustment mode on the RX
nothing is level at mid stick!
Do I adjust the servo arms and linkages to level my swash plate or attempt to fly it as it is?
Time to create page: 0.605 seconds
