deviation-devo7e-v5.0.0 dsm2/dsmx issue
24 Jun 2016 07:43 #51025 by seurat
Hi Developers,
I would like to report an issue with the deviation-devo7e-v5.0.0 build regarding the DSM2/DSMX protocols:
I tried to bind and noticed that, after binding to an AR6335 receiver, the servo movements where not smooth; they were broken, as though the receiver where dropping packets.
The I noticed that in Model menu -> Model setup the protocol spinner doesn't show the telemetry if I press ENT while on it.
This is working fine in v4.0.1 and in deviation-devo10-v5.0.0 !
I have created a bug tracker entry.
01 Aug 2016 14:25 #52370 by kyleman7
Replied by kyleman7 on topic deviation-devo7e-v5.0.0 dsm2/dsmx issue
I am also having issues with my devo7e on v5.0.0 The radio output seems all crazy, bouncing up and down randomly. When I tried to use it as a usb-hid also you could see that the roll and pitch axes were clean but the thrust and rudder were a mess, it didn't matter which mode I had the sticks set in.
02 Aug 2016 17:49 #52391 by Thomas.Heiss
Replied by Thomas.Heiss on topic deviation-devo7e-v5.0.0 dsm2/dsmx issue
Do you have any chance to source check-out / build previous nightly-build 4.0.1-fcd0669? I was successfully flying this build on DSMx.
www.deviationtx.com/forum/3-feedback-que...been-fixed-yet#36873
www.deviationtx.com/forum/protocol-devel...port?start=340#33913
Release 5.0 incorporates some DSM protocol changes, which I have not tested yet - not sure about other Deviation pilots:
www.deviationtx.com/forum/protocol-devel...port?start=400#46358
26 Aug 2016 09:56 #53118 by Thomas.Heiss
www.deviationtx.com/forum/builds/6306-ni...v4-0-1-fcd0669#53115
Just downloaded Devo10 zip previously.
Sorry, for Devo7E you would have to build yourself from repository sources.
Time to create page: 0.895 seconds
