Binding D4R-II
- cody
23 Jul 2016 19:47 #52060
by cody
Binding D4R-II was created by cody
I have installed a multimodule in my Devo 7E but can not bind my D4R-II receiver.
I press the bind button on the receiver, switch it on and select bind in Deviation.
Then I switch it off and on but the LED stays red.
I have selected FrSky as protocol. Also tried FrSky-V8 with the same result.
What could be the problem?
24 Jul 2016 08:32 #52074
Replied by mwm on topic Binding D4R-II
In the model setup, select the FrSky (not V8) protocol, then select that button to open the protocol options. There are a couple of tubing adjustments. Try the fine one at intervals of about 20 until it binds. Then run up and down from there to get the points where it disconnects, and sweet it to the average of those two values.
- cody
- C0ckpitvue 777
21 Sep 2016 02:09 - 21 Sep 2016 02:10 #54079
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Binding D4R-II
What type of range are you getting?cody wrote: Works now.
Thank you!
Last edit: 21 Sep 2016 02:10 by C0ckpitvue 777.
- Nixie
08 Feb 2017 19:12 #58942
by Nixie
Replied by Nixie on topic Binding D4R-II
I have had the same problem. I have -50 range now.
-20 < bind < -80
-20 < bind < -80
Time to create page: 0.300 seconds
- Binding D4R-II
